C# mapscript...
Tamas Szekeres
szekeres.tamas at FREEMAIL.HU
Tue Mar 7 18:36:30 EST 2006
John,
It seems you are using the CGI version. I've just compiled the nightly build
and could work with IIS (XPSP1 IIS 5.1).
1. Which files do you have in your directory
2. How did you configure IIS
3. What was you url?
I've used anonymous access and integrated security enabled
Execute Permissions: Scrips and Executables
Windows firewall disabled...
Use filemon to check all of the files could be accessed...
Tamas
On Tue, 7 Mar 2006 10:07:41 -0600, John Cole <john.cole at UAI.COM> wrote:
>Howard,
> I'm trying to get your 4.8.1 build (thank you for making that) to work
>with IIS. Searching the website, there isn't a guide on setting this up.
>I've gotten IIS to work with MS4W before, but I'm getting a 502 when I try
>to hit this version.
> Mapserv -v returns the following:
>C:\Inetpub\cgi-bin>mapserv -v
>MapServer version 4.8.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
>SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
>SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPO
>RTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=SDE INPUT=POSTGIS INPUT=OGR
>INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
>So I'm pretty sure it's ready to go, and I've also made a decent stab at
>getting the permissions correct. Is there something that I've missed?
>I'm on XP SP2 IIS 5
>Thanks,
>John Cole
>-----Original Message-----
>From: Howard Butler [mailto:hobu at iastate.edu]
>Sent: Monday, March 06, 2006 9:53 AM
>To: John Cole; MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: Re: C# mapscript...
>John,
>Grab the build kit. All of the dependencies have been built
>already. All you have to worry about are gdal and mapserver.
><http://hobu.stat.iastate.edu/mapserver/build_output/mapserver-4.8-msvc71-bu
>ild-kit.zip>
>Make sure to edit nmake.opt for GDAL and make a clean GDAL (and then
>do nmake /f makefile.vc install). Edit nmake.opt for MapServer, make
>clean, and make install for MapServer and you should end up with a
>csharp directory in ..\bin with the C# mapscript binaries.
>Catch me on IRC if you have questions. Then we can write a doc ;)
>Howard
>At 09:42 AM 3/6/2006, John Cole wrote:
>>Tamas,
>> Thanks for your help, some more questions now :-)
>> I've switched to the nightly.tar.gz (because I couldn't figure out flex
>>and bison) but I'm having trouble with libpng. I've checked their site and
>>there isn't a lot of info on building with windows, much less building in
>>VC8, how did you do it? I'm getting the following error trying to build
>the
>>libpng solution
>>Error 1 fatal error A1000: cannot open file :
>>c:\projects\zlib\contrib\masmx86\inffas32.asm MASM
>>I have the zlib library but that file doesn't exist in it (nor does the
>>masmx86 directory).
>> Also, I was the nmake /F Makefile.vc was getting errors on not finding
>>bgd_i.lib, so I changed those references to bgd.lib, is that OK? (it got
>>past that).
>>Thanks,
>>John Cole
>>From: Tamas Szekeres [mailto:szekeres.tamas at FREEMAIL.HU]
>>Sent: Friday, March 03, 2006 3:58 PM
>>To: MAPSERVER-USERS at LISTS.UMN.EDU; John Cole
>>John,
>>The parser and lexer files are not precompiled with the CVS version. You
>>have at least 2 options to do:
>>1. Use the nightly build instead containing theese files precompiled
>>http://cvs.gis.umn.edu/dist/nightly.tar.gz
>>2. Download flex and bison
>>gnuwin32.sourceforge.net/packages/flex.htm
>>gnuwin32.sourceforge.net/packages/bison.htm
>>and generate theese files from mapparser.y and maplexer.l
>>Best Regards,
>>Tamas
