error log?
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Fri Mar 10 10:17:42 EST 2006
Hi Jeremy,
make sure Mapserver is compiled with MSDEBUG (check with mapserv -v).
Then define an environment variable called MS_ERRORFILE, if you are
using Apache add the following to the Apache conf:
SetEnv "MS_ERRORFILE" "stderr"
and restart Apache. If you are using IIS, define a system env. variable
and restart the system.
Mapserver will then log in the webserver's error log. You could also
specify a file instead of stderr, but then make sure the webserver user
has enough rights on this file.
Best regards,
Bart
Sears, Jeremy wrote:
>Hi All,
>Can anyone tell me if and how Mapserver logs errors?
>Im tryin to debug an application and having a report of what mapserver is
>choking on would make things much smoother!
>Thanks
>Jeremy
OSGIS, Open Source GIS
http://www.osgis.nl
