500 internal server error
Puneet Kishor punkish at EIDESIS.ORG
Sun Mar 12 14:29:32 EST 2006
On Mar 12, 2006, at 1:03 PM, Apeksha Bhambhani wrote:
> Hii all,
> While running Mapserver on our localhost , as :
> http://localhost/cgi-bin/mapserv  it gives the "500 internal server
> error" .
> The server encountered an internal error or misconfiguration and was
> unable to complete your request.
> Please contact the server administrator, root at localhost and inform
> them of the time the error occurred, and anything you might have done
> that may have caused the error.
> More information about this error may be available in the server error
> log.
> We are working on root . On checking the error log the following
> messages were retrieved :
> [Sun Mar 12 23:27:12 2006] [error] [client 127.0.0.1] (13)Permission
> denied: exec of '/var/www/cgi-bin/mapserv' failed
That is a clue. Check your permissions. Make sure Apache is configured
to execute files in that cgi-bin, and that cgi-bin itself has correct
permissions chmod-ed (and chown-ed).
> However using the Php/Mapscript API we are able to display the images .
That is being executed in a different directory which probably has the
correct permissions, hence, it works.
Puneet Kishor
