Point Layer Won't Draw
Delfos, Jacob jacob.delfos at MAUNSELL.COM
Mon Mar 13 17:31:20 EST 2006
Lawrence,
Any chance your point file is a "multi point" (Multipoint ZM) ? I am not
sure, but I think Mapserver *may* still have problems with that. I know
that 3D files now work, but multipoints may not. Open your shapefile in
ArcGIS (f you can), and look at the value in the "shape" column of the
attribute table.
Regards,
Jacob
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Lawrence Hartpence
> Sent: 14 March 2006 05:28
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Point Layer Won't Draw
> My mapfile is at the bottom.  This shapefile is in the same
> projection as
> the other shapefiles.  I created a very simple map site
> trying to find the
> problem.  You can see the website at
> http://216.203.113.94/jaspermaps/temp_i.htm
> When I change the name of the shapefile to another point
> layer in the same
> directory, it works.  It really seems that there is something
> wrong with the
> layer, but I don't know what.
> Lawrence
> NAME "temp"
> UNITS feet
> SIZE 639 491
> IMAGECOLOR 255 255 255
> IMAGETYPE gif
> EXTENT 1680507.39 547052.00 1844030.00 680312.51
> FONTSET "C:\MS4W\Apache\htdocs\fontset.txt"
> SYMBOLSET "C:\MS4W\Apache\htdocs\symbols.sym"
> CONFIG PROJ_LIB "C:\ms4w\proj\nad\"
> WEB
>     TEMPLATE "C:\MS4W\Apache\htdocs\temp.html"
>     IMAGEPATH "C:\MS4W\tmp\ms_tmp\"
>     IMAGEURL "/JasperMaps/ms_tmp/"
> END
> LAYER
>    NAME "Monuments"
>    STATUS default
>    TYPE point
>    DATA "C:\parcels_shape\ctl2005"
>    CLASS
>      SYMBOL 'circle'
>      SIZE 20
>      COLOR 0 255 0
>    END
> END
> LAYER
>    NAME "County"
>    STATUS default
>    TYPE polygon
>    DATA "C:\parcels_shape\county"
>     CLASS
>         NAME "County"
>         STYLE
>             OUTLINECOLOR 212 192 100
>         END
>     END
> END
> END
