Problem with reprojected images
Frank Warmerdam
warmerdam at POBOX.COM
Tue Mar 14 11:53:50 EST 2006
Stephen Woodbridge wrote:
> Dirk Jesko wrote:
>> Ed,
>> I already thought of something like this already. However, this should
>> not happen. If the images are seamless (our images are seamless and do
>> not have any borders) in the original projection, they should also be
>> seamless after a reprojection. Otherwise, I would call it a bug.
> May be, may be not! In a continuous math world this might be true, but
> pixels are not continuous, this might be caused by a rounding or
> numerical percision cause the pixel location to fall inside or outside
> of the patch.
>> I just tested an older version of Mapserver (4.6.1). That one creates
>> seamless results, even if the images are reprojected. Only newer
>> versions (tested 4.8.1) produce non-seamless images. Can someone
>> confirm this?
> Well a behavior change can certainly be considered a bug :) In which
> case you might want to submit a simple test case (like two tiles and a
> mapfile) the reproduct the results.
Folks,
I have to confess I haven't been following this discussion closely. There
were fixes for 4.8.x intended to address cracking problems reported by a
user. I can't recall the details but we can, if needed, dig back into the
history logs.
I would appreciate a submitted bug report with a *minimal* demonstration
of the problem. My minimal, I mean a map file with two images in a tile
index and that I can just run "shp2img -m abc.map -o abc.png" to test.
Please ensure the bug report is assigned directly to me.
Once I reproduce the problem, I can try and analyse what is going wrong.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
