translate to tcl
Lowell.Filak
lfilak at MEDINACO.ORG
Tue Mar 14 13:23:29 EST 2006
salah jubeh writes:
> CAN ANY BODY HELP ME IN TRANSLATE THIS TO TCL
> map = mapscript.Map('rquery.map')
> layer = map.getLayer(0)
> pnt = mapscript.Point()
> pnt.x = 440780 pnt.y = 3751260
> layer.queryByPoint( map, pnt, mapscript.MS_MULTIPLE, 180.0 )
> layer.open() for i in range(1000):
> result = layer.getResult( i )
> if result is None:
> break
> print '(%d,%d)' % (result.shapeindex, result.tileindex)
> s = layer.getShape( result.shapeindex, result.tileindex )
> for i in range(layer.numitems):
> print '%s: %s' % (layer.getItem(i), s.getValue(i))
> layer.close()
Salah,
Assuming that this probably relates to the question you posted some time ago
regarding TCLMapScript I'm going to attempt to supply some history that may
or may-not help as it is all I can do in regards to TCL.
The last time I recall seeing any "active" maintenance/support for the TCL
flavor of MapScript is in version 3.3 (maybe 3.5). That doesn't mean that
the TCL version doesn't work but there are a few issues that you may run
into. Basically the TCL interface is maintained via SWIG from the C source
code and is/can-be recreated in an automated fashion for each release but I
do not recall any replies to TCL questions recently outside of Sean G. who
usually provides great support for the MapScript API "in depth" but may not
be able to help with specifics for TCL. This is the same method used for the
Java, Perl, Python, Ruby versions. This does leave a support position open
that you could fill once you are more familiar with it ;-)
The other issue I know of is (at least at the time of 3.3) that TCL does/did
not have a direct "module" for accessing Xbase files outside of mapscript so
there were objects/methods/routines placed into mapscript to allow the tcl
interface to access field names, values, & etc. At first when the older
perlmapscript (my finger tires of capitalizing) documentation was done those
objects & etc. where documented but proved to cause more trouble than it was
worth when a person could simply include "use XBase" or such and access the
information through an API that was intended for that purpose. That said, I
think Sean has once again included documentation for said objects & etc. as
of 4.4. As a starting point you could use the base swigmapscript
documentation and see what works & what doesn't.
As an example of a specific issue, until the event of a patch during the
life of 4.4 and then in 4.6 you could not hold an imageobj in a scalar in
the perl version due to the lack of a swig typemap (which has since been
created).
Lowell
