PERL Mapscript
Stephen Davies
sdc at SDC.COM.AU
Tue Mar 14 23:27:49 EST 2006
I am having my first attempt at using PERL/Mapscript to save map images
to files and am not getting too far.
I have a map file that works perfectly when used with:
http://server/cgi-bin/mapserv?map=/tmp/q.map&mapext=139.5143351+-34.7459112+139.5278707+-34.7207
I have the following PERL test bed:
#! /usr/bin/perl
# args are UID (for mapfile), pic sequence #, image type (extension),
map extent
use strict;
use mapscript;
my $uno = $ARGV[0];
my $seq = $ARGV[1];
my $ext = $ARGV[2];
my $minx = $ARGV[3];
my $miny = $ARGV[4];
my $maxx = $ARGV[5];
my $maxy = $ARGV[6];
my $mapfile = "/tmp/$uno.map";
my $map = mapscript::mapObj->new($mapfile);
$map->setExtent($minx,$miny,$maxx,$maxy);
my $img = $map->prepareImage();
$img = $map->draw();
my $fname = "/var/www/html/status_images/$uno_$seq.$ext";
print "$fname\n";
$img->save($fname);
Called as:
./genpics q 1 139.5143351 -34.7459112 139.5278707 -34.7207
This generates a blank jpeg file (of some 2800 bytes).
What am I missing?
Cheers and thanks,
Stephen Davies
MapServer version 4.8.0-rc2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER SUPPORTS=WCS_SERVER
SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
This email is for the person(s) identified above, and is confidential to
the sender and the person(s). No one else is authorised to use or
disseminate this email or its contents.
Stephen Davies Consulting Voice: 08-8177 1595
Adelaide, South Australia. Fax: 08-8177 0133
Computing & Network solutions. Mobile:0403 0405 83
