Problem with reprojected images
Dirk Jesko ml.dje at GEOCONTENT.DE
Wed Mar 15 02:59:42 EST 2006
Frank,
thanks for the help. I will prepare a test case later and submit it.
Until a solution is found for this, we will switch back to version 4.6.1.
Regards,
Dirk
> Folks,
> I have to confess I haven't been following this discussion closely.
> There
> were fixes for 4.8.x intended to address cracking problems reported by a
> user.  I can't recall the details but we can, if needed, dig back into
> the
> history logs.
> I would appreciate a submitted bug report with a *minimal* demonstration
> of the problem.   My minimal, I mean a map file with two images in a tile
> index and that I can just run "shp2img -m abc.map -o abc.png" to test.
> Please ensure the bug report is assigned directly to me.
> Once I reproduce the problem, I can try and analyse what is going wrong.
> Best regards,
