PHP MapScript 4.8.1 and PHP 5.1.2
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Thu Mar 16 13:35:02 EST 2006
David,
While I have not run PHP 5, it is likely that TrueType fonts in PHP 4
and Mapserver are coming from the system libraries and the PHP 5 is
using TrueType or GD libraries that might be bundled with the PHP 5
distribution. PHP has historically come with a bundled version of GD
that is used to build it by default and it is important that you you
build it and mapserver using the SAME GD, TrueType, and Regex libraries
or you WILL get segmentation faults.
-Steve W.
David Badke wrote:
> We were having a problem running PHP MapScript 4.8.1 under PHP 5.1.2
> (Red Hat Linux). Using TrueType fonts caused segmentation faults; bitmap
> fonts did not. The server guys have now changed things so that our
> application runs under PHP 4.4.2, and "magically" the problem went away.
> I am not entirely convinced that it was a PHP 5 problem.
> My question: Can anyone definitively say that PHP MapScript 4.8.1 does
> or does not work under PHP 5.1.2, particularly with regard to the use of
> TrueType fonts? The last message I can find on this topic is a year old,
> with no clear conclusion.
> David
