FW: [UMN_MAPSERVER-USERS] WAN vs LAN access problems
Sears, Jeremy
Jeremy.Sears at CCRS.NRCAN.GC.CA
Thu Mar 16 14:30:17 EST 2006
fowarding to the list ...
-----Original Message-----
Sent: March 16, 2006 2:20 PM
To: 'Bart van den Eijnden (OSGIS)'
Subject: RE: [UMN_MAPSERVER-USERS] WAN vs LAN access problems
Hi Bart,
Thanks for the response. I think that the server does have an internal and
external address. The mapserver installed on my serverer is reachable to WAN
only thru a proxy. As I mentioned, the mapserver is installed off of the
root in a directory simmilar to: /adirectory/anotherdirectory/ms4w. When a
request from WAN is made to the mapserver, a proxyserver directs it to
/adirectory/anotherdirectory, which is where I have
mapserver/apache/chameleon installed.
>>If you view the HTML source of your application, what URL do the images
>>reference?
When I attempt to view the page from WAN
The images are referenced as:
https://myhttp.address.ca/chameleon//skins/default/images/a_pixel.gif
When I view the page from our LAN
http://myLAN.address/chameleon//common//wrapper/drawmap.php?map_session_mode
=1&run_query=0&sid=4419b8d118a98&dummy=0.39865000+1142536402&UniqId=11425363
97803538
Both of the above noted URLs are what is returned when I query the
properties of the main map image via a right-mouse-click
Any thoughts?
Thanks
Jeremy
From: Bart van den Eijnden (OSGIS) [mailto:bartvde at xs4all.nl]
Sent: March 16, 2006 1:53 PM
To: Sears, Jeremy
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] WAN vs LAN access problems
Does your machine have an internal and external IP address?
reference?
Best regards,
Bart
Sears, Jeremy wrote:
>Hi All,
>IM having a problem with my mapserver installation ....
>I have mapserver/chameleon setup with ms4w on winserver2003.
>When I view my application from our LAN (either localhost or another
>computer on the LAN) the application works fine.
>However, when I attempt to view the application from the WAN, chameleon's
>elements work but neither the main map image nor the keymap image work.
>I have the entire ms4w package installed in in a location off the root
like:
>Does anyone have any thoughts as to why the app works fine when accessed
>from LAN but breaks when accesing through WAN?
>Thanks
>Jeremy
OSGIS, Open Source GIS
http://www.osgis.nl
