Value list in expression-field
Tim Schaub
tim at COMMENSPACE.ORG
Fri Mar 17 10:48:38 EST 2006
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Dmitri Mizerkin
> Sent: Friday, March 17, 2006 8:09 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] Value list in expression-field
> Hi all!
> An extract from my mapfile looks like this:
> LAYER
> NAME Sel_Streets
> DATA Streets
> STATUS OFF
> TYPE LINE
> CLASSITEM "OBJECTID"
> class
> NAME 'Selected streets'
> expression '%oid%'
> STYLE
> COLOR 255 0 0
> END
> end
> END
> What should I change in the expression-line to be able to
> provide not a single value to filter features by, but a range
> of values (for example, {12,15,63})?
You should be able to set your oid (or other variable) to a URL encoded
version of this:
(([OBJECTID] == 12) OR ([OBJECTID] == 15) OR ([OBJECTID] == 63))
> Should be something with 'IN'-keyword, but I can't find out,
> what the right syntax is...
Or maybe there is some easier way - I haven't heard of IN.
Tim
> Thanks in advance!
> Dmitri
> http://www.nabble.com/Value-list-in-expression-field-t1298405.
> html#a3457524
> Sent from the Mapserver - User forum at Nabble.com.
