Improving Performance... {Scanned}
Jelmer Baas
baas at SPEERIT.NL
Mon Mar 20 00:58:12 EST 2006
Siki Zoltan wrote:
> Hi,
> Probaly you use MS XP, there is a limitation, one program is limited to
> use 2GB RAM only on a 32 bit system. On Xp 64 bit no memory limit (or
> higher?).
> Try to create the spatial index on a linux box ;)
> An other solution is to split your shape file into smaller tiles and
> use ogrtindex to create tileindex. It may make faster your application.
> Make an index for each tile and for the tile index too.
Though it's getting a tad offtopic, I'll try doing this. You're right,
I'm running on Windows 2003 Server (32 bit). For the layers that DID
convert, I found that most layers rendered faster with OGR and .TAB
files than they did with SHP :-)
Jelmer
