Improving Performance... {Scanned}
Jelmer Baas baas at SPEERIT.NL
Mon Mar 20 08:45:40 EST 2006
Siki Zoltan wrote:
> Are you sure mapserver uses your index?
> If you write
> DATA someting.shp
> in your map file qix index will not be used
> You must delete the extension e.g
> DATA something
Yep, it used the index. I also tried it when it DIDN'T use the index,
but then it took a few minutes to render the image :-)
Jelmer
