Tutorial / 500 Internal Server Error
Pericles S. Nacionales naci0002 at UMN.EDU
Mon Mar 20 13:20:22 EST 2006
My apologies.  I misunderstood you.  I thought you were running the tutorial
locally and were getting the messages on your machine...  It turns out it's
my server!  I updated the server last week and the MapServer (actually GDAL)
dependencies got screwed up.  You should be able to use it again later today.
(tomorrow for you ;)
-Perry
On Monday 20 March 2006 11:26, Dave Stone wrote:
> Thanks for the reply, guys, but I don't understand why you're asking for
> these details; are the error messages not being generated at your end, by
> your Apache/MapServer?
> What I'm doing, typically, is clicking on a link to an example (1.8, say)
> so the URL I'm trying to access is:
> http://hypnos.cbs.umn.edu/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdoc
>s/ example1-8.map&layers=states+states_label+modis&mode=map
> The page displays OK except for the map, which shows as a small icon; when
> this is clicked, the following error appears:
> "Internal Server Error
> The server encountered an internal error or misconfiguration and was unable
> to complete your request.
> Please contact the server administrator, root at localhost and inform them of
> the time the error occurred, and anything you might have done that may have
> caused the error.
> More information about this error may be available in the server error log.
> Apache/2.0.54 (Gentoo/Linux) PHP/4.4.0-pl1-gentoo with Hardening-Patch
> Server at hypnos.cbs.umn.edu Port 80"
> This looks like your server, so checking our error logs would be
> superfluous surely?
> What has me really confused about this problem is that up till March 9th, I
> was working through the tutorial without any problems, accessing all the
> example files on your server AFAIK.
Conservation Biology Program
University of Minnesota
e-mail: naci0002 at umn.edu
