Mac OS X installers Panther vs Tiger
William Kyngesburye
woklist at KYNGCHAOS.COM
Mon Mar 20 23:08:34 EST 2006
Ah. That's an odd issue with MapServer's configure script. It
checks for static libraries for many things, including proj. I don't
include static libraries in my packages. I edit configure to check
for dynamic libraries instead. If you use BBEdit or TextWrangler, I
use this find/replace:
grep: (lib(png|jpeg|gd|proj|pdf|Xpm)).a
with: \1.dylib
Also, just to make sure to use the libXpm in my GraphicsLibs, replace
all '-lX11' in configure with nothing (that is, delete -lX11).
It should affect more than just proj (see the grep line above), but
maybe you have built some of the other dependencies in /usr/local in
the past?
On Mar 20, 2006, at 8:45 PM, Allan Doyle wrote:
> On 3/20/06, William Kyngesburye <woklist at kyngchaos.com> wrote:
>> Well, I've been considering Python mapscript. Things that have been
>> stalling me are:
>> - waiting for the Universal MacPython
>> - recent focus on getting everything Universal
>> - I wasn't sure of the status/stability/feature parity of python
>> mapscript
>> - I forgot (that universal thing, again, pushed a lot to the back of
>> my mind)
>> I have built it before as a test. What's the problem with PROJ? My
>> installers include proj 4.4.9, is there a some build error?
> I don't think there's a build error, but to build python mapscript,
> simply using --with-proj=/usr/local/gislibs does not work. So I built
> proj and installed it into a dummy location so that the mapscript for
> python build would be able to pick it up.
> Allan
>> On Mar 20, 2006, at 5:31 PM, Allan Doyle wrote:
>>> First of all, thanks for the great packages!
>>> I just voted for Tiger-only. But I'm a pretty small-potatoes user,
>>> I suspect your poll may get skewed by that kind of thing.
>>> However, as long as you're asking, I did run into trouble the other
>>> day not being able to build python mapscript after having installed
>>> all the Mac packages. I wrote this up:
>>> http://www.eogeo.org/Members/adoyle/ad-snippets/pymapscript-build
>>> If I did something really stupid, please let me know...
>>> Allan
>> William Kyngesburye <kyngchaos at kyngchaos.com>
>> http://www.kyngchaos.com/
>> "History is an illusion caused by the passage of time, and time is an
>> illusion caused by the passage of history."
>> - Hitchhiker's Guide to the Galaxy
"I ache, therefore I am. Or in my case - I am, therefore I ache."
- Marvin
