shptree and tileindex
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Tue Mar 21 14:41:45 EST 2006
David,
I don't think the sequence matters at all.
I have found in the past that there is a problem with locating the
quadtree index files if the location attribute contains the .shp
extension. Use something like filemon to find out for your system and
please report back to the list.
Best regards,
Bart
Hunter, David - St. Louis Park, MN wrote:
> When using a combination of the shptree and tileindex utilities, does
> it matter which order they are ran? I have tile-indexed my data first,
> and then ran shptree on the individual shape files and the tileindex
> files. It occurred to me that the tileindex files point to the .shp
> files, and wondered if this is optimized. (I read somewhere that you
> should not specify file extensions in .map files when using quad
> indexes, I’m wondering if this is true also in the tileindex files.)
> Do I need to tileindex the shape files after quad-indexing them, and
> then quad-index the tileindex files, or am I obsessing over nothing?
> *David S. Hunter*
> /Sr. Software Engineer
> Fidelity National Geographic Solutions
> division of Fidelity National Financial
> 5353 Gamble Drive, Suite 201
> St. Louis Park, MN 55416
> /š /Email: david.hunter at fnf.com <mailto:david.hunter at fnf.com>
> /' /Phone: 952.542.1440 ext. 256
> /7 /Fax: 952.542.3859///
OSGIS, Open Source GIS
http://www.osgis.nl
