copyright text bottomright but mapsize variable
Bart van den Eijnden
bartvde at XS4ALL.NL
Wed Mar 22 03:24:10 EST 2006
Hi list,
is it possible to have a copyright layer in the bottom right part of the
map image, in a situation in which the map size is variable (without
side-effect of the text being in the middle of the map image when the
image size increases :-) )?
Or is it necessary to use Mapscript to change the point coordinates of the
label in case the map size changes?
Thanks in advance.
Best regards,
Bart
