extra spatial filter for OVF source
Frank Warmerdam
warmerdam at POBOX.COM
Wed Mar 22 10:28:21 EST 2006
Huub Fleuren wrote:
> Hi List
> http://www.google.com/search?hl=en&lr=&rls=GGLD%2CGGLD%3A2004-28%2CGGLD%3Aen&q=ODBC+gdal+spatial+filters+VRT+format+howto
> I was hoping that i could put an extra spatial filter (a polygon : find
> all point within the polygon) to the following OVF source
> Is it possible?
> How?
Huub,
I don't know how this would be accomplished without changing some code,
though I can see that it would be an interesting capability for the OGR
VRT (OVF) driver. If you just wanted a one time static extract it wouldn't
be to hard to setup with a Python script but doing it dynamically is
not currently supported.
Best regards,
> Thanks in advance
> <OGRVRTDataSource>
> <OGRVRTLayer name='wwal'>
> <SrcDataSource>ODBC:admin/admin at anwb</SrcDataSource>
> <SrcSQL>SELECT k.kp_nr as kp_nr,k.x as x, k.y as y,
> w.wegbeheerdercode as wegbeheerdercode, w.onderhoudsinstantiecode as
> onderhoudsinstantiecode FROM wwall w, kpxy k WHERE NOT (k.soort LIKE
> 'D') and (w.x > 190000) and (w.x < 200000) and (w.y > 500000)
> and (w.y < 520000) and (w.kruispuntnummer = k.kp_nr)</SrcSQL>
> <GeometryType>wkbPoint</GeometryType>
> <LayerSRS>WGS84</LayerSRS>
> <GeometryField encoding='PointFromColumns' x='x' y='y'/>
> </OGRVRTLayer>
> </OGRVRTDataSource>
and watch the world go round - Rush | President OSGF, http://osgeo.org
