copyright text bottomright but mapsize variable
Huub Fleuren
hfl at HOME.NL
Wed Mar 22 13:50:47 EST 2006
Bart,
you might want to lay a static (inhome designed) copyright image on top
of your map. If you 'drag' the image, maybe your client gives you the
flexibility to let this top image be and just operate on the images
stacked under it.
Regards, Huub
Stephen Woodbridge wrote:
> See bugs #1547 and #1592 and a gentle prod of the owners would hurt :)
> -Steve W
> Bart van den Eijnden wrote:
>> Hi list,
>> is it possible to have a copyright layer in the bottom right part of the
>> map image, in a situation in which the map size is variable (without
>> side-effect of the text being in the middle of the map image when the
>> image size increases :-) )?
>> Or is it necessary to use Mapscript to change the point coordinates
>> of the
>> label in case the map size changes?
>> Thanks in advance.
>> Best regards,
>> Bart
