Possibly a silly question ?
Steve Pashby
s.pashby at POSTGRAD.CURTIN.EDU.AU
Thu Mar 23 01:28:08 EST 2006
Frank Warmerdam <warmerdam <at> POBOX.COM> writes:
> Steve Pashby wrote:
> > Hello,
> > Just a quick question ... can MapServer read data from ESRI's
geodatabase.
> > I've just tried accessing some data (and failed), but am not sure if its
> > because MapServer cannot read data in a geodatabase, or if its my Mapfile !
> Steve,
> MapServer can utilize ESRI Personal Geodatabase (.mdb) files on Win32
> platforms *if* you have a sufficiently recent version of OGR in your
> MapServer build (at least GDAL 1.3.1).
> Of course there are lots of things that could be going wrong.
> I would encourage you to first verify that access to your personal
> geodatabase is working properly with ogrifo.
> Of course, if you mean another one of the ESRI geodatabase options
> (geodatabase in SDE, etc) then different issues apply.
> Best regards,
I have GDAL 1.3.1.0 and have eventually managed to open the geodatabase
(via 'PGeo' driver?!) But how then do you put this into a Mapfile (CONNECTION
TYPE PGeo ... and then the name of the file and continue as per a shapefile?)
I'm afraid i'm a bit of new to this and have only worked with shapefiles to
date - but need to branch out !
Thanks for your help.
Steve.
