drawLabelCache problem in 4.8.2
Paul Moen
pmoen at STATE.ND.US
Thu Mar 23 14:39:36 EST 2006
This may be related to my problem with symbols in the label. If you are
using a symbol to label try commenting it out to see if it will label with
text.
>The annotation layer for the line shape works when the symbol is not used.
>Therefore, something is wrong with the way I use my symbol. This worked in
>4.8.1. So, the new question is what is wrong with my symbol and the way I
>am using it?
>On 3/23/06 9:35 AM, "Paul Moen" <pmoen at state.nd.us> wrote:
>> My ANNOTATION layer line types worked in 4.8.1 and do not in 4.8.2. The
httpd
>> daemon takes all
>> the processor and times out in 60 seconds when I zoom to a level the label
>> appears. This only
>> seems to be a problem on the annotation for line layers.
>> LAYER # Line Shape File
>> NAME "a_State and Federal Roads"
>> DATA roadsstatefed
>> GROUP "Transportation"
>> TEMPLATE "noexist"
>> STATUS ON
>> TYPE ANNOTATION
>> LABELITEM "HWY"
>> CLASS
>> TYPE ANNOTATION
>> MAXSCALE 1000000
>> NAME "0_0"
>> EXPRESSION ('[RTE_SIN]' eq 'S')
>> COLOR 0 0 0
>> SYMBOL "../symbols/largerimages/sthwy.gif"
>> LABEL
>> MINFEATURESIZE 50
>> MINDISTANCE 150
>> SIZE SMALL
>> COLOR 0 0 0
>> END
>> END # Standard Road Signs - State
>> END
>> This works for the polygon layer countypoly.
>> LAYER # Polygon shap file
>> NAME "a_Counties"
>> DATA countypoly
>> GROUP "Political Boundaries"
>> STATUS ON
>> TYPE ANNOTATION
>> LABELITEM "NAME_CAPS"
>> CLASS
>> NAME "0"
>> TYPE ANNOTATION
>> EXPRESSION ('[NAME_CAPS]' eq 'MOUNTRAIL')
>> MINSCALE 500000
>> LABEL
>> FONT timesbold
>> TYPE TRUETYPE
>> OUTLINECOLOR 150 255 150
>> SIZE 7
>> COLOR 100 100 100
>> ANGLE AUTO
>> PARTIALS FALSE
>> POSITION CC
>> END
>> END
>> I get no errors in http error_log or in the console.log. Did something
change
>> that makes my
>> annotation layer definitions for lines wrong? Can anyone see if there is
>> something that I am
>> missing or did something break in 4.8.2?
>> Thanks,
>> Paul Moen
On 3/23/06 1:09 PM, "Jeff Hoffmann" <jeff at PROPERTYKEY.COM> wrote:
> I'm setting up a new server and decided to go with the newest version of
> MapServer, but I'm having a problem with getting one of my perl scripts
> to run. I've isolated the problem to the call to drawLabelCache -- once
> the script hits that line, it pegs the CPU until the web server request
> times out. I've run the same script on probably every 4.x version of
> MapServer there is up til now without problems, so I went and grabbed a
> copy of the 4.8.1 source and compiled it on that machine & it worked
> fine, so I'm guessing that some sort of bug got introduced between releases.
Paul T. Moen
701-328-2434
701-328-3696 (fax)
ND State Water Commission
