How to increase resolution of image?
Aaron Koning
aaronkoning at GMAIL.COM
Thu Mar 23 17:31:54 EST 2006
Yes, the map elements should be scaled as well. Otherwise, when printed,
they appear smaller than the web-map. This is not a fun task, because you
have to worry about a layer's scale dependency, are the labels being sized
proportionally, etc. I also wonder if this is a feature request in
MapServer? Seems to be a common topic throughout the years.
Aaron
On 3/23/06, Paul Moen <pmoen at state.nd.us> wrote:
> Thank you for your response Flavio.
> Does that mean that all sizes of map elements must be sized larger so they
> scale with the map?
> Does anyone know if this is something that is being worked on or has been
> a
> feature request? Can GD or Imagemagick scale the image to an 8 x 8 at 150
> dpi without degrading the image?
> On 3/23/06 2:30 AM, "Flavio Hendry" <flavio at TYDAC.CH> wrote:
> > Hi Paul
> > "resolution" is normally defined as dots or pixels per inch. a "naked"
> > image has therefore no resolution, just a size. anyway, you are on the
> > right way, you just have to "force" your 1200x1200 pixels image into an
> > 8"x8" rectangle in your pdf. which would in this case end up to 1200
> > dots / 8 inch = 150 dpi.
> > Mit freundlichem Gruss / Best Regards
> > Flavio Hendry
> > TYDAC NEWS http://www.tydac.ch/german/index.php?menu=News_actual
> > ############ Mit freundlichen Gruessen / Kind Regards
> > ############ mailto:flavio at tydac.ch
> > ############ TYDAC AG - http://www.tydac.ch
> > #### #### Geographic Information Solutions
> > #### #### Luternauweg 12 -- CH-3006 Bern
> > ############ Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
> Thank you,
> Paul T. Moen
> 701-328-2434
> 701-328-3696 (fax)
> ND State Water Commission
| Aaron Koning
| Information Technologist
| Prince George, BC, Canada.
| http://datashare.gis.unbc.ca/fist/
| http://datashare.gis.unbc.ca/gctp-js/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060323/f35889cb/attachment.html
