Map files for dummies?
Ed McNierney ed at TOPOZONE.COM
Fri Mar 24 17:33:27 EST 2006
Dave -
Your EXTENT is in China, so if your shapefile is in Texas it won't show
up.  Your Y-coordinate (longitude) values should be negative numbers in
the Western Hemisphere, and should be reversed so the minimum value
(more negative) comes first.  I expect ogrinfo is really reporting
negative numbers - if it's not, then your data are in error.
     - Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
Phone: +1 (978) 251-4242
Fax: +1 (978) 251-1396
ed at topozone.com
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Dave Nuttall
Sent: Friday, March 24, 2006 2:09 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Map files for dummies?
I have an instance of Mapserver 4.8.1 running on CentOS with Apache
2.20, PHP 5.1.2 and Mapscript running as a DSO.
I can make/display maps where I use the canned tutorials.  But I'm
failing to create map displays when I substitute shapefiles that are of
local interest.
The shapefiles in question are apparently valid, since I can read them
without any problems using "ogrinfo -al shapefile.shp".
I extract the decimal dimensions and create my own *.map file, but all I
ever get is the layer for pseudo-credits.
If someone could tweak my map file (which follows), it would be a
valuable learning experience for me.
TIA.
Dave Nuttall
San Antonio, TX
Here is my map file:
MAP
    NAME BEXAR2
    STATUS ON
    SIZE 400 300
    IMAGETYPE PNG
    IMAGECOLOR 240 240 240
    SHAPEPATH "/var/www/data/texas"
    # the extents were pulled from the shape file with ogrinfo
    EXTENT 29.114435 98.116613 29.760630 98.806552
    UNITS DD
            LAYER
                        NAME "Bexar County"
                        TYPE POLYGON
                        STATUS ON
                        DATA "tgr48029all"
    # don't know if this projection is valid!
                        PROJECTION
                           "proj=latlong"
                           "ellps=GRS80"
                           "datum=NAD83"
                        END
                        CLASS
                        NAME "Bexar County"
                        OUTLINECOLOR 90 90 90
                        COLOR 0 255 0
                        END
END
# End of map layer
# This credits layer always works/displays!
            LAYER
                                     NAME "credits"
                                     STATUS DEFAULT
                                     TRANSFORM FALSE
                                     TYPE ANNOTATION
                                     FEATURE
POINTS 10 290
                                     END
                                     TEXT 'Made with Mapserver. AIM to
see it.'
            END
            CLASS
                                    LABEL
                                    TYPE BITMAP
                                    POSITION CR
                                    COLOR 0 0 0
                                    END
                        END
END
# end of credits layer
END
# end of bexar2.map for Bexar County, Texas.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060324/062a5aba/attachment.html
