Map files for dummies?
Flavio Hendry flavio at TYDAC.CH
Sat Mar 25 03:59:53 EST 2006
Hi Dave
see http://umn.mapserver.ch/ ... lots of explanations and examples.
Mit freundlichem Gruss / Best Regards
Flavio Hendry
TYDAC NEWS http://www.tydac.ch/german/index.php?menu=News_actual
############      Mit freundlichen Gruessen / Kind Regards
############             mailto:flavio at tydac.ch
############         TYDAC AG - http://www.tydac.ch
####    ####        Geographic Information Solutions
####    ####         Luternauweg 12 -- CH-3006 Bern
############   Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
-----Original Message-----
To: MAPSERVER-USERS at LISTS.UMN.EDU
Date: Fri, 24 Mar 2006 13:09:17 -0600
Subject: [UMN_MAPSERVER-USERS] Map files for dummies?
> I have an instance of Mapserver 4.8.1 running on CentOS with Apache
> 2.20,
> PHP 5.1.2 and Mapscript running as a DSO.
> I can make/display maps where I use the canned tutorials.  But I'm
> failing
> to create map displays when I substitute shapefiles that are of local
> interest.
> The shapefiles in question are apparently valid, since I can read
> them
> without any problems using "ogrinfo -al shapefile.shp".
> I extract the decimal dimensions and create my own *.map file, but
> all I
> ever get is the layer for pseudo-credits.
> If someone could tweak my map file (which follows), it would be a
> valuable
> learning experience for me.
> TIA.
> Dave Nuttall
> San Antonio, TX
> Here is my map file:
> MAP
>     NAME BEXAR2
>     STATUS ON
>     SIZE 400 300
>     IMAGETYPE PNG
>     IMAGECOLOR 240 240 240
>     SHAPEPATH "/var/www/data/texas"
>     # the extents were pulled from the shape file with ogrinfo
>     EXTENT 29.114435 98.116613 29.760630 98.806552
>     UNITS DD
>             LAYER
>                         NAME "Bexar County"
>                         TYPE POLYGON
>                         STATUS ON
>                         DATA "tgr48029all"
>     # don't know if this projection is valid!
>                         PROJECTION
>                            "proj=latlong"
>                            "ellps=GRS80"
>                            "datum=NAD83"
>                         END
>                         CLASS
>                         NAME "Bexar County"
>                         OUTLINECOLOR 90 90 90
>                         COLOR 0 255 0
>                         END
> END
> # End of map layer
> # This credits layer always works/displays!
>             LAYER
>                                      NAME "credits"
>                                      STATUS DEFAULT
>                                      TRANSFORM FALSE
>                                      TYPE ANNOTATION
>                                      FEATURE
> POINTS 10 290
>                                      END
>                                      TEXT 'Made with Mapserver. AIM
> to see
> it.'
>             END
>             CLASS
>                                     LABEL
>                                     TYPE BITMAP
>                                     POSITION CR
>                                     COLOR 0 0 0
>                                     END
>                         END
> END
> # end of credits layer
> END
> # end of bexar2.map for Bexar County, Texas.
