Problems with Itasca Demo
72555 davide.albertini at TICINO.COM
Mon Mar 27 08:11:26 EST 2006
Hallo,
I'm a new MapServr user, I started to install mapserver with the ms4w
1.4.1
and I got no errors, so I decided to install the MapServer demo
"workshop" downloaded from the main sit of map server.
I followed the instruction but I can't get the right page when try to
initialize the demo.
This is the configuration that I've did:
Error Log:
[Thu Mar 23 13:59:51 2006] [error] [client 127.0.0.1] script not
found or unable to stat: C:/Program Files, referer:
http://127.0.0.1/workshop/index.html
[Thu Mar 23 14:21:26 2006] [error] [client 127.0.0.1] script not
Index.html (C:\MS4W\Apache\htdocs\workshop\):
<html>
  <head>
    <title>MapServer Itasca Application</title>
    <script language="javascript">
      function submit_form() {
        var template =
document.demo.map_web_template.options[document.demo.map_web_template.
selectedIndex].value;
        if(template.indexOf("frame") != -1) document.demo.action =
"frames.html";
        if(template.indexOf("dhtml") != -1) document.demo.action =
"frames_dhtml.html";
    </script>
  </head>
  <body bgcolor="#FFFFFF">
    <center><h2>MapServer Itasca Application</h2></center>
    <p><hr><p>
    This demonstration application will take you through various
levels of complexity. Starting with a basic application that
    allows a user to pan/zoom and change layers we add:
    <ul>
      <li> dynamically configured scalebars
      <li> javascript-based panning
      <li> query results to a frame
      <li> and finally, a DHTML rubber-band zoom/query capabilty
    </ul>
    The base data is the old-reliable Itasca dataset that we know and
love...
    <!-- EDIT THE FORM ACTION -->
    <form name="demo" method="GET" action="\cgi-bin\mapserv.exe"
onSubmit="submit_form()">
      <input type="hidden" name="layer" value="lakespy2">
      <input type="hidden" name="layer" value="dlgstln2">
      <input type="hidden" name="zoomsize" value=2>
      <!-- EDIT THESE HIDDEN VARIABLES -->
      <input type="hidden" name="map"
value="C:\ms4w\Apache\htdocs\workshop\itasca.map">
      <input type="hidden" name="program"
value="C:ms4w\Apache\cgi-bin\mapserv.exe">
      <input type="hidden" name="root"
value="C:\ms4w\Apache\htdocs\workshop">
      <input type="hidden" name="map_web_imagepath"
value="C:\ms4w\Apache\htdocs\tmp">
      <input type="hidden" name="map_web_imageurl"
value=C:\ms4w\Apache\htdocs\tmp">
      <select name="map_web_template" size="1">
        <option value="itasca_basic.html"> Basic Application
        <option value="itasca_adds_scalebar.html"> &nbsp;&nbsp;--
Adds second scalebar
        <option value="itasca_adds_pan.html"> &nbsp;&nbsp;-- Adds pan
controls
        <option value="itasca_adds_frames.html"> &nbsp;&nbsp;-- Adds
frames
        <option value="itasca_adds_dhtml.html"> &nbsp;&nbsp;-- Adds
dhtml rubber-band box
      </select>
      <input type="submit" value="Initialize"></center>
    </form>
    <p><hr><p>
  </body>
</html>
Changes in itasca.map:
 # change this value to match your setup
 WMS_ONLINERESOURCE "http://localhost/workshop/index.html"
Changes in httpd.conf:
ServerRoot "C:\ms4w\Apache"                      --> Line 57
DocumentRoot "C:\ms4w\Apache\htdocs"               --> Line 228
Thanks for the help , I tried with the mailing list but I can't login.
Greetings.
