Using Microsoft SQL Server?
Van Ulden, Joost
jvanulde at NRCAN.GC.CA
Mon Mar 27 12:15:56 EST 2006
Hi Chip, here are some snippets you can use:
# Microsoft SQL Server
LAYER
NAME [insert your layer name without spaces (eg. my_layer)]
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION
'<OGRVRTDataSource>
<OGRVRTLayer name="[insert your layer name]">
<SrcDataSource>ODBC:[insert user_name]/[insert password]@[insert
dsn name],[insert table name]</SrcDataSource>
<SrcLayer>[insert table name]</SrcLayer> # OR <SrcSQL>[insert
your sql statement (eg. SELECT Longitude,Latitude,... FROM
MyTable)]</SrcSQL>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>WGS84</LayerSRS>
<GeometryField encoding="PointFromColumns" x="[insert field name
(eg. Longitude)]" y="[insert field name (eg. Latitude)]"/>
</OGRVRTLayer>
</OGRVRTDataSource>'
DUMP TRUE # for WFS only
DATA "[insert your layer name]"
STATUS default
CLASS
SYMBOL 'circle'
SIZE 25
COLOR 255 0 0
END
END
# FileMaker
LAYER
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION
'<OGRVRTDataSource>
<SrcDataSource>ODBC:[insert your dsn name],[insert your database
<SrcSQL>[insert your sql statement (eg. SELECT
Longitude,Latitude,... FROM Earthquake)]</SrcSQL>
</OGRVRTLayer>
STATUS default
CLASS
SYMBOL 'circle'
SIZE 25
COLOR 255 0 0
END
END
# Microsoft Access
LAYER
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION
'<OGRVRTDataSource>
<SrcDataSource>ODBC:[insert your dsn name],[insert your table
<SrcLayer><insert your table name></SrcLayer>
</OGRVRTLayer>
STATUS default
CLASS
SYMBOL 'circle'
SIZE 25
COLOR 255 0 0
END
END
# GML
LAYER
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION '[insert your directory path here]\[insert your filename
here].gml'
DATA "[insert the featureType here (eg. point | line | polygon)]"
STATUS default
CLASS
SYMBOL 'circle'
SIZE 25
COLOR 255 0 0
END
END
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Chip Taylor
Sent: Friday, March 24, 2006 7:19 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Using Microsoft SQL Server?
Can I integrate a layer in Mapserver using a connection to Microsoft SQL
Server 2005, pulling XY (lat long) points and text, and plot these? How
would I do that?
Chip Taylor
Prepared Response, Inc
