shapefile optimization for dynamic data
Chris Tweedie
chris at NARX.NET
Mon Mar 27 19:51:04 EST 2006
Ben, for the situation you described i would of thought pushing the GPS
points into a database would make much more sense than trying to
add/remake the shapefile especially at that frequency.
Have you looked into using postgis (or any other db for that matter) as
your datasource?
Chris
Quoting Stephen Woodbridge <woodbri at SWOODBRIDGE.COM>:
> Using shptree will not help you that much in this scenario because of
> the frequency of updating the file. You best bet would be use
> multiple files and a tile index that you would have to add the new
> files to as they are created. Then you can shptree on the non-active
> file, but not on the active file. That will probably be the best
> scenario. Also make sure you shptree the tileindex.
> If a shapefile does not have a qix spatial index, then mapserver
> creates one on the fly and throws it away. If you are adding a point
> a second the file is probably getting updated faster than you can
> index it and then render it. Using the tileindex should really help
> in this case also, because only the files the intersect you current
> display window need to be opened and looked at.
> -Steve W.
> Ben Eisenbraun wrote:
>> Hi-
>> I'm building a Mapserver application with dynamic data coming in
>> every second, and I'm not sure how to organize the shapefiles for
>> speediest access.
>> I'm collecting data via a GPS and a sensor that reports a data point
>> once per second. I'm using Mapserver CGI to generate an overlay
>> onto a map via a javascript frontend that auto-refreshes every few
>> seconds. The application has to run on a low-power embedded
>> hardware device (roughly a p2-266), and I'm running into performance
>> problems once I've collected a few thousand data points. The
>> Mapserver CGI process tends to consume all the CPU trying to render
>> the overlays.
>> Up to now, I've been using shpadd/dbfadd to add the data points to a
>> single shapefile. I've tried using shptree to index the shapefile,
>> but under my
>> testing, it doesn't seem to speed up rendering time at all. The
>> largest a shapefile should ever get to be is about 25,000 data
>> points; I'm not sure if that's large or small compared to other
>> people's data.
>> I've thought about breaking up that single shapefile into multiple
>> shapefiles of a given size, but I'm not sure if that would be a win
>> for this type of situation.
>> Given that I'm constantly updating the source shapefile, what are my options
>> for optimizing it?
>> Thanks for any tips or pointers.
>> -ben
>> simplicity is the most difficult thing to secure in this world; it
>> is the last limit of experience and the last effort of genius.
>> <george sand>
