shapefile optimization for dynamic data
Ben Eisenbraun bene at KLATSCH.ORG
Mon Mar 27 22:56:28 EST 2006
The possibility of using the sqlite driver popped up a while back,
but at the time I discounted it based on suggestions from the mailing
list that properly optimized shapefiles were going to offer the fastest
access.
Thanks for the suggestions.  I'll take a look at postgis.  If we go that
route, I suppose I should set up fastcgi for connection pooling too.
-ben
On Mon, Mar 27, 2006 at 10:16:20PM -0500, Stephen Woodbridge wrote:
> Chris,
> I would have suggested that also, but I think in the use case presented
> which is an embedded system most likely excluded that as an option, but
> maybe that was a poor assumption on my part. If you can install
> postgres/postgis that would be ideal, otherwise I think something like I
> suggested would probably work best.
> Ben, let us know what works best for you.
> -Steve
> Chris Tweedie wrote:
> >Ben, for the situation you described i would of thought pushing the GPS
> >points into a database would make much more sense than trying to
> >add/remake the shapefile especially at that frequency.
> >Have you looked into using postgis (or any other db for that matter) as
> >your datasource?
> >Chris
> >Quoting Stephen Woodbridge <woodbri at SWOODBRIDGE.COM>:
> >>Using shptree will not help you that much in this scenario because of
> >>the frequency of updating the file. You best bet would be use multiple
> >>files and a tile index that you would have to add the new files to as
> >>they are created. Then you can shptree on the non-active file, but not
> >>on the active file. That will probably be the best scenario. Also make
> >>sure you shptree the tileindex.
> >>If a shapefile does not have a qix spatial index, then mapserver
> >>creates one on the fly and throws it away. If you are adding a point a
> >>second the file is probably getting updated faster than you can index
> >>it and then render it. Using the tileindex should really help in this
> >>case also, because only the files the intersect you current display
> >>window need to be opened and looked at.
> >>-Steve W.
> >>Ben Eisenbraun wrote:
> >>>Hi-
> >>>I'm building a Mapserver application with dynamic data coming in
> >>>every second, and I'm not sure how to organize the shapefiles for
> >>>speediest access.
> >>>I'm collecting data via a GPS and a sensor that reports a data point
> >>>once per second.  I'm using Mapserver CGI to generate an overlay onto
> >>>a map via a javascript frontend that auto-refreshes every few
> >>>seconds.  The application has to run on a low-power embedded hardware
> >>>device (roughly a p2-266), and I'm running into performance problems
> >>>once I've collected a few thousand data points.  The Mapserver CGI
> >>>process tends to consume all the CPU trying to render the overlays.
> >>>Up to now, I've been using shpadd/dbfadd to add the data points to a
> >>>single shapefile.  I've tried using shptree to index the shapefile,
> >>>but under my
> >>>testing, it doesn't seem to speed up rendering time at all.  The
> >>>largest a shapefile should ever get to be is about 25,000 data
> >>>points; I'm not sure if that's large or small compared to other
> >>>people's data.
> >>>I've thought about breaking up that single shapefile into multiple
> >>>shapefiles of a given size, but I'm not sure if that would be a win
> >>>for this type of situation.
> >>>Given that I'm constantly updating the source shapefile, what are my
> >>>options
> >>>for optimizing it?
> >>>Thanks for any tips or pointers.
> >>>-ben
> >>>simplicity is the most difficult thing to secure in this world; it is
> >>>the last limit of experience and the last effort of genius.
> >>><george sand>
error of opinion may be tolerated where the reason is left free to combat
it.                                                    <thomas jefferson>
