mapserver demo WORKSHOP does not work correctly
Steve Lime steve.lime at DNR.STATE.MN.US
Tue Mar 28 02:05:27 EST 2006
Try adding a trailing '/' to the value for map_web_imageurl. That should fix things. The DHTML example works because it doesn't use temporary images at all.
Steve
>>> steven_zb <zibiao.zhang at UMB.EDU> 03/27/06 10:13 PM >>>
Hi All,
I have installed mapserver4.0 on Redhat 9. when I ran the demo Workshop,
something I can not understand happened: among the five options from the
homepage, only "Adds Dhtml Rubber Band box" worked perfectly. all others
would give me a page, but no image was shown. I checked with /tmp/ folder,
images were created every time when I tried to open the page. following is
the confguration from index.html and the error log file. all comments are
welcome please:
<!-- EDIT THESE HIDDEN VARIABLES -->
      <input type="hidden" name="map"
value="/var/www/html/mapserver/itasca.map">
      <input type="hidden" name="program" value="/cgi-bin/mapserv_40">
      <input type="hidden" name="root" value="/mapserver">
      <input type="hidden" name="map_web_imagepath"
value="/var/www/html/mapserver/tmp/">
      <input type="hidden" name="map_web_imageurl" value="/mapserver/tmp">
22:36:58 2006] [error] [client 68.160.131.246] File does not exist:
/var/www/html/mapserver/tmpITASCAref114351701828523.png, referer:
http://wpcl.cs.umb.edu/cgi-bin/mapserv_40?layer=lakespy2&layer=dlgstln2&zoomsize=2&map=%2Fvar%2Fwww%2Fhtml%2Fmapserver%2Fitasca.map&program=%2Fcgi-bin%2Fmapserv_40&root=%2Fmapserver&map_web_imagepath=%2Fvar%2Fwww%2Fhtml%2Fmapserver%2Ftmp%2F&map_web_imageurl=%2Fmapserver%2Ftmp&map_web_template=itasca_basic.html
View this message in context: http://www.nabble.com/mapserver-demo-WORKSHOP-does-not-work-correctly-t1353515.html#a3623213
Sent from the Mapserver - User forum at Nabble.com.
