Converting Polygon Shapefile
Sean Gillies
sgillies at FRII.COM
Tue Mar 28 12:20:57 EST 2006
There are tutorial-ish examples of programming with ogr.py at
http://zcologia.com/news/16
http://www.perrygeo.net/wordpress/?p=4
cheers,
Sean
On Mar 28, 2006, at 10:08 AM, Bart van den Eijnden (OSGIS) wrote:
> You could load it into PostGIS, let PostGIS calculate the centroid and
> export it again to shape using e.g. ogr2ogr.
> You probably could also write an OGR Python script doing this.
> Best regards,
> Bart
> Chip Taylor wrote:
>> Is there an open source utility that will convert a polygon
>> shapefile to a
>> point shapefile, using the centroid of the polygon as the xy for
>> the point?
>> Chip Taylor
>> Prepared Response, Inc
> OSGIS, Open Source GIS
> http://www.osgis.nl
Sean Gillies
http://zcologia.com
