[UNCLASSIFIED]RE: [UMN_MAPSERVER-USERS] Using a web image as a ma
p layer
Antti Roppola
Antti.Roppola at BRS.GOV.AU
Tue Mar 28 19:53:46 EST 2006
I did this once by creating a world file to georeference the image,
It was quite a while ago but I recall it was pretty straight forward.
For your example, your GDAL build will need to support GIF or you
will need to convert the image to a supported format first.
Antti
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Mark Howard
Sent: Wednesday, 29 March 2006 11:10 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Using a web image as a map layer
Anybody know how to use an image off the web as a map layer?
I'm thinking of an image that's updated periodically - such as:
http://www.intellicast.com/WeatherImg/Satellite/world.gif
Ideas? (simple ideas?)
TIA!!
Mark
IMPORTANT - This message has been issued by The Department of Agriculture, Fisheries and Forestry (DAFF). The information transmitted is for the use of the intended recipient only and may contain confidential and/or legally privileged material. It is your responsibility to check any attachments for viruses and defects before opening or sending them on.
Any reproduction, publication, communication, re-transmission, disclosure, dissemination or other use of the information contained in this e-mail by persons or entities other than the intended recipient is prohibited. The taking of any action in reliance upon this information by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error please notify the sender and delete all copies of this transmission together with any attachments. If you have received this e-mail as part of a valid mailing list and no longer want to receive a message such as this one advise the sender by return e-mail accordingly. Only e-mail correspondence which includes this footer, has been authorised by DAFF
