no joy: Bill Kropla's "Beginning Mapserver"
Frank Warmerdam
warmerdam at POBOX.COM
Wed Mar 29 00:12:11 EST 2006
KevinC (UD) wrote:
> Luis, Bill sez in his book "The shapelib build isn't configuration
> based". When I try your suggestion I get:
> # ./configure --with-proj=/usr/local/lib
> ./configure: No such file or directory
> This is not unexpected.
> Frank Warmerdam, I made the changes as prescribed to
> shapelib-1.2.10/contrib/Makefile
> but no success.
> Bill Kropla instructs me to switch to tests/ , but I think he means
> contrib/ , then
> [root at ud5 contrib]# make check
> tests/shpproj.sh
> rm: cannot remove `test*': No such file or directory
> ../shpproj: error while loading shared libraries: libproj.so.0: cannot
> open shared object file: No such file or directory
> failure...
> So again ,the build cannot find Proj4 libraries.
Kevin,
With respect in this case the executable is not finding libproj.so
at *runtime*, not build time. A completely different animal. You
likely need to set the LD_LIBRARY_PATH environment variable to point
to (or include) /usr/local/lib, or fiddle with /etc/ld.conf to include
that directory and then re-run ldconfig.
Please disregard any impoliteness or bad spelling in the above. I'm
most of the way through a bottle of my mother-in-laws homemade wine.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
