tileindex: sequence of attributes in individual shapefiles matter s
Jeff McKenna jmckenna at DMSOLUTIONS.CA
Wed Mar 29 09:32:20 EST 2006
and no error was thrown when generating the index?  I swear I've hit
this same problem when one dbf had a different field, and an error was
displayed.
jeff
Eijnden, B. van den (Bart) wrote:
> Hi list,
> today we encountered that the sequence of attributes of the individual
> shapefiles which were used in a tile-index are important. In 3 out of 4
> shapefiles the CLASSITEM column was the 3rd column, but in the 4th shapefile
> it was the 4th column, so that one did not show up in the map ....
> Apparently Mapserver fetches attribute values based on a column index? Would
> it be better to fetch by name? Otherwise I think this requirement should be
> documented somewhere.
> Best regards,
> Bart
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
