tileindex: sequence of attributes in individual shapefiles
matter s
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Wed Mar 29 10:33:05 EST 2006
Hi Bart,
It does fetch by name from the first file that is opened but then
remembers the indexes. If you use tile4ms, this now checks for these
kinds of errors and trows and error. Mapserver can open 10 of thousands
of files when drawing a layer and this would add a lot of additional
overhead to fetch the column numbers based on names for every file.
I know it is a pain, but your should fix the data. It would not be hard
to write a little perl script to read the dbf file and reorder the
attributes.
-Steve W
Eijnden, B. van den (Bart) wrote:
> Hi list,
> today we encountered that the sequence of attributes of the individual
> shapefiles which were used in a tile-index are important. In 3 out of 4
> shapefiles the CLASSITEM column was the 3rd column, but in the 4th shapefile
> it was the 4th column, so that one did not show up in the map ....
> Apparently Mapserver fetches attribute values based on a column index? Would
> it be better to fetch by name? Otherwise I think this requirement should be
> documented somewhere.
> Best regards,
> Bart
> Disclaimer
> Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
> uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
> hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
> informeren. Wij adviseren u om bij twijfel over de juistheid of de
> volledigheid van de mail contact met afzender op te nemen.
> This message shall not constitute any rights or obligations.
> This message is intended solely for the addressee.
> If you have received this message in error, please delete it and
> notify the sender immediately. When in doubt whether this message
> is correct or complete, please contact the sender.
