tileindex: sequence of attributes in individual shapefiles matter s
Bart van den Eijnden (OSGIS) bartvde at XS4ALL.NL
Wed Mar 29 10:55:15 EST 2006
Hi Steve,
okay, good to know tile4ms checks for this sort of thing, ogrtindex
doesn't throw errors ...
Best regards,
Bart
Stephen Woodbridge wrote:
> Hi Bart,
> It does fetch by name from the first file that is opened but then
> remembers the indexes. If you use tile4ms, this now checks for these
> kinds of errors and trows and error. Mapserver can open 10 of
> thousands of files when drawing a layer and this would add a lot of
> additional overhead to fetch the column numbers based on names for
> every file.
> I know it is a pain, but your should fix the data. It would not be
> hard to write a little perl script to read the dbf file and reorder
> the attributes.
> -Steve W
> Eijnden, B. van den (Bart) wrote:
>> Hi list,
>> today we encountered that the sequence of attributes of the individual
>> shapefiles which were used in a tile-index are important. In 3 out of 4
>> shapefiles the CLASSITEM column was the 3rd column, but in the 4th
>> shapefile
>> it was the 4th column, so that one did not show up in the map ....
>> Apparently Mapserver fetches attribute values based on a column
>> index? Would
>> it be better to fetch by name? Otherwise I think this requirement
>> should be
>> documented somewhere.
>> Best regards,
>> Bart
>> Disclaimer
>> Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
>> uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
>> hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
>> informeren. Wij adviseren u om bij twijfel over de juistheid of de
>> volledigheid van de mail contact met afzender op te nemen.
>> This message shall not constitute any rights or obligations.
>> This message is intended solely for the addressee.
>> If you have received this message in error, please delete it and
>> notify the sender immediately. When in doubt whether this message
>> is correct or complete, please contact the sender.
OSGIS, Open Source GIS
http://www.osgis.nl
