Mapserver CGI + ArcSDE 8.3 windows build ?
listuser HH listuser at HERZSYS.DE
Thu Mar 30 04:31:22 EST 2006
James Perrins wrote:
>Hi,
>We've been trying using the kitchen sink builds from
>http://hobu.stat.iastate.edu/mapserver/
>However we need to install onto a machine that has Arc SDE 8.3 and the build
>on here seems to require SDE 9.0
>Does anyone know where we can get a build using SDE 8.3 or does anyone have
>a windows build they could let us have ?
>I've never actually gone through the build process and would rather avoid it
>if I can !
>Many Thanks
>James
Hi James,
I had a problem some weeks ago with the arcsde client 82 on SuSE SLES 9.
Because ESRI don't support linux very good and the SDE client had a
problem with system lib I had to take the SDE client 9.0. I know you are
on windows but on linux this seem to work. The SDE client should be
backward compatible. I could use the SDE client 9.0 with the SDE db
version 8.2 so you can try to get and use the SDE client 9.0.
Regards
Norbert
