Defining a line from SQL server using OGR
Chip Taylor work at XWB.COM
Thu Mar 30 10:00:23 EST 2006
I am retrieving a set of point from SQL Server using OGR.  If I declare the
layer type to be "Point" then it works fine.  However, I want the series of
XY coordinates to define a line.  If I declare the layer type "Line" nothing
renders.  Any help would be appreciated.  Here is the layer code defined as
a line (there are two xy points in the database):
# Tracking
LAYER
  NAME GPSLayer1
  TYPE Point
  CONNECTIONTYPE OGR
  CONNECTION
 '<OGRVRTDataSource>
       <OGRVRTLayer name="GPSData">
        <SrcDataSource>ODBC:myUser/myPwd at myDSN</SrcDataSource>
       <SrcSQL>EXEC pGetTracking</SrcSQL>
       <GeometryType>wkbLineString</GeometryType>
        <GeometryField encoding="PointFromColumns" x="gpsLongitude"
y="gpsLatitude"/>
      </OGRVRTLayer>
  </OGRVRTDataSource>'
  DATA "GPSData"
  CLASSITEM "gpsDeviceId"
  STATUS off
  CLASS
          EXPRESSION /Device1/
          STYLE
                 COLOR 90 0 255
                 OUTLINECOLOR 0 255 0
                 SYMBOL 'BigLine'
                 SIZE 40
          END
  END
 END
########### End of Tracking Layer ###############
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060330/de8a3601/attachment.html
