Serving raster images via MapServer?
Armin Burger armin.burger at GMX.NET
Thu Mar 30 16:20:23 EST 2006
Thom,
I found it a perfect solution to store the tileindex vectors in a
PostGIS database. It makes the use of tileindexes (image catalogs) more
flexible. It's possible to set SQL filters on the tileindex layers.
All updates are easily to achieve, just need to send SQL commands with
whatever programming language you want to Postgis to reference a new
image. Spatial indexes are updated automatically too. And you can keep
additional metadata also in the database.
The only requirement is to use 2 instead of one layer definition for the
image catalog.
Armin
Thom DeCarlo wrote:
> Hey Ed,
> (So, you and Norm are over here, too. Small world!)
> This sounds good. I've been reading up on the gdaltindex and I think I
> understand how to get it set up. But, what is this shptree thing you
> mentioned?
> Also, two other issues. First, the client is going to be continually
> requesting map updates and the server will be getting frequent additions to
> its repository. If the tile index is held in a shapefile will the MapServer
> re-read that file when a new client request comes in or is it only read when
> Mapserver starts?
> Second, since I've already got a PostgreSQL server managing the vector data,
> can the tile index be held in it, too? I'm going to have a lot of
> overlapping imagery and it seems (to the novice that I am) that SQL queries
> could find the best/newest data to serve out to the client. Or, is this just
> unnecessary overhead?
