Serve GeoTIFF with Mapserver
Norman Barker
nbarker at RSINC.COM
Fri Mar 31 04:10:50 EST 2006
From: Steven De Vriendt [mailto:gisaalter at gmail.com]
Sent: Friday, March 31, 2006 10:06 AM
To: Norman Barker
Cc: MAPSERVER-USERS at lists.umn.edu
Subject: Re: [UMN_MAPSERVER-USERS] Serve GeoTIFF with Mapserver
Norman, thanks for your quick reply. I've did some cut and paste work
based on your tutorial, thanks !
This is my mapfile, I think 10meg is quite big for posting here, so I
think I have to leave you with this mapfile...Thanks for helping out !
MAP
NAME DEMO
STATUS ON
SIZE 500 500
SYMBOLSET ../etc/symbols.sym
EXTENT 77336.359625 189988.500250 90937.297125 201812.968625
UNITS METERS
SHAPEPATH "/ms4w/apps/chameleon/samples/data/topo"
IMAGECOLOR 125 125 125
FONTSET ../etc/fonts.txt
TRANSPARENT FALSE
PROJECTION
"init=epsg:31300"
END
OUTPUTFORMAT
NAME GEOTIFF
DRIVER "GDAL/GTiff"
MIMETYPE "image/tiff"
IMAGEMODE "RGB"
EXTENSION "tif"
END
WEB
IMAGEPATH "c:/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
"wms_title" "Aalter_WMS"
"wms_onlineresource" "
http://10.109.2.100/cgi-bin/mapserv.exe?map=/ms4w/apps/chameleon/samples
/map/wmsserver.map
<http://10.109.2.100/cgi-bin/mapserv.exe?map=/ms4w/apps/chameleon/sample
s/map/wmsserver.map> &"
"wcs_description" "Orthospot mosaic"
"wcs_name" "TOPO"
"wcs_label" "Topokaart"
"ows_srs" "EPSG:31300"
"ows_extent" "77336.359625 189988.500250 90937.297125 201812.968625"
"wcs_resolution" "381 381"
"wcs_bandcount" "1"
"wcs_formats" "GEOTIFF"
"wcs_nativeformat" "8-bit GeoTIF"
END
END
LAYER
NAME topokaart
DATA t136n.tif
TYPE RASTER
STATUS ON
PROCESSING "SCALE=AUTO"
DUMP TRUE
METADATA
"wms_title" "AALTER"
END
TRANSPARENCY 0
OFFSITE 255 255 255
PROJECTION
"init=epsg:31300"
END
END
END
From: UMN MapServer Users List [mailto: MAPSERVER-USERS at LISTS.UMN.EDU]
On Behalf Of Steven De Vriendt
Sent: Friday, March 31, 2006 9:21 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Serve GeoTIFF with Mapserver
Related to the raster serving images question, I'd like to ask if
there's a reference
for serving geotiff files ? What do I need to specify more in the map
file
for letting mapserver to do this. I've tried with the WCS tutorials but
I
think I'm missing out on something because I can't see my geotiff...
Steven,
Any chance you can post your map file, and a sample (small) geotiff? I
have used MapServer WCS a lot, and it is very good / stable.
Gail Millin and myself wrote a tutorial here
http://mapserver.gis.umn.edu/docs/howto/WCSServerFormatHowTo that may be
of use as well.
Norman
Hi Steven,
You seem to be mixed up between a WMS and WCS (see the processing option
in your map file, and the geotiff format with RGB), you can send the
10mb tiff to me directly (not to the list) and I will see if I can get
it working, and post back the map file. I think the more WCS map file
examples we can get out the more it will be adopted.
Norman
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060331/e82a5207/attachment.html
