setting STYLE with CGI parameters
Paul Ramsey pramsey at REFRACTIONS.NET
Fri Mar 31 18:11:35 EST 2006
I think you have to enumerate all the unnameable elements for which
there are potentially more than one entry. (Not sure if we count from
0 or 1)
&map_mylayer_class_0_style_0_width=3
P
On 31-Mar-06, at 2:57 PM, Brock Anderson wrote:
> Hi All,
> I am trying to use CGI parameters to dynamically set the WIDTH and
> OUTLINECOLOR within a STYLE tag.  I've tried various formats for
> the CGI parameters, including something like:
>    &map_mylayer_class_style_1_width=3
> ... but the parameters are being ignored.  Is it possible to use
> CGI parameters to set values within a STYLE element?  How?
> Brock
> I'm using Mapserver 4.6.2.  A piece of my map file:
> LAYER
>  NAME "mylayer"
>  CONNECTIONTYPE postgis
>  CONNECTION "..."
>  DATA "..."
>  CLASS
>    EXPRESSION ([pop] > 5000)
>    NAME "above 5000"
>    STYLE
>      COLOR 0 197 255
>    END #end style
>    STYLE
>      OUTLINECOLOR 0 197 255
>      WIDTH 5
>    END #end style
>  END #end class
>  TYPE polygon
>  STATUS DEFAULT
>  PROJECTION
>    "init=epsg:4269"
>  END #projection
> END #LAYER
