displaying rasters with negative pixel values
Chris Garrard
chrisg at BIOLOGY.USU.EDU
Mon May 8 18:04:47 EDT 2006
Hi Chris,
I tried adding the scale_buckets directive, and it didn't help. I had
also tried using geotiffs instead of erdas files, and got the same
results with either. But it works fine with or without scale_buckets
once I converted the image to 16 bit.
Thanks!
Chris
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Christopher Condit
> Sent: Monday, May 08, 2006 2:31 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] displaying rasters with
> Hi Chris-
> Here's an excerpt from a mapfile that works for me. There are two
> differences:
> 1) I use the SCALE_BUCKETS processing directive. Try adding this.
> 2) I haven't tried Erdas formats, which run through GDAL or MapServer.
> All the formats I've used are coming through GDAL. So the
> question is:
> is your MapServer compiled with Erdas support? If so then there's a
> difference there as well.
> Run a mapserv -v and check to see if INPUT=EPPL7 is there.
> There could be something else that's totally obvious, too, and we're
> just not seeing it.
> -Chris
> DATA "surfaceTemperature.txt"
> NAME "Surface Temperature"
> OFFSITE 0 0 0
> PROCESSING "SCALE_BUCKETS=30"
> PROJECTION
> "init=epsg:4326"
> END
> TEMPLATE "..\templates\search.html"
> TYPE RASTER
> UNITS DD
> CLASS
> NAME "-1.928 to -0.866"
> EXPRESSION ([pixel] >= -1.9275 and [pixel] < -0.86574)
> METADATA
> END
> STYLE
> ANGLE 360
> COLOR 0 0 255
> SYMBOL 0
> END
> END
> CLASS
> NAME "-0.866 to 0.196"
> EXPRESSION ([pixel] >= -0.86574 and [pixel] < 0.19602)
> METADATA
> END
> STYLE
> ANGLE 360
> COLOR 13 27 254
> SYMBOL 0
> END
> END
> CLASS
> Behalf Of Chris Garrard
> Sent: Monday, May 08, 2006 10:17 AM
> Subject: Re: [UMN_MAPSERVER-USERS] displaying rasters with negative
> pixel values
> Hi Chris,
> Thanks for looking at this. Here's the map file. It displays classes
> c5 - c10 just fine, and shows part of the data from the c4 class. I
> have big blank areas for classes c1 - c3. If I use either of the
> commented-out processing directives instead of the classes, I
> still get
> the blank areas. The image displays fine in other software, so I know
> the data are there.
> MAP
> NAME utah
> EXTENT -1510000 -285000 -1020000 375000
> UNITS METERS
> IMAGETYPE png
> SIZE 450 450
> OUTPUTFORMAT
> NAME PNG
> DRIVER "GD/PNG"
> MIMETYPE "image/png"
> IMAGEMODE RGBA
> EXTENSION "png"
> TRANSPARENT OFF
> END
> WEB
> IMAGEPATH "/webgis/apache/htdocs/tmp/"
> IMAGEURL "/tmp/"
> END
> LAYER
> NAME mintemp
> TYPE raster
> STATUS default
> DATA '/auto/earth2/ars_data/statedata/utah/ut_tmin.img'
> # PROCESSING "SCALE=AUTO"
> # PROCESSING "SCALE=-7,10"
> CLASS
> NAME 'c1'
> TITLE '(-7) - (-6)'
> EXPRESSION ([pixel] >= -7 AND [pixel] <= -6)
> COLOR 0 0 255
> END
> CLASS
> NAME 'c2'
> TITLE '(-5.9) - (-4)'
> EXPRESSION ([pixel] > -6 AND [pixel] <= -4)
> COLOR 54 97 255
> END
> CLASS
> NAME 'c3'
> TITLE '(-3.9) - (-2)'
> EXPRESSION ([pixel] > -4 AND [pixel] <= -2)
> COLOR 56 171 255
> END
> CLASS
> NAME 'c4'
> TITLE '(-1.9) - 0'
> EXPRESSION ([pixel] > -2 AND [pixel] <= 0)
> COLOR 0 255 255
> END
> CLASS
> NAME 'c5'
> TITLE '0 - 1'
> EXPRESSION ([pixel] > 0 AND [pixel] <= 1)
> COLOR 145 255 181
> END
> CLASS
> NAME 'c6'
> TITLE '1.01 - 2'
> EXPRESSION ([pixel] > 1 AND [pixel] <= 2)
> COLOR 209 255 105
> END
> CLASS
> NAME 'c7'
> TITLE '2.01 - 3'
> EXPRESSION ([pixel] > 2 AND [pixel] <= 3)
> COLOR 255 255 0
> END
> CLASS
> NAME 'c8'
> TITLE '3.01 - 4'
> EXPRESSION ([pixel] > 3 AND [pixel] <= 4)
> COLOR 255 184 0
> END
> CLASS
> NAME 'c9'
> TITLE '4.01 - 6'
> EXPRESSION ([pixel] > 4 AND [pixel] <= 6)
> COLOR 255 112 0
> END
> CLASS
> NAME 'c10'
> TITLE '6.01 - 10'
> EXPRESSION ([pixel] > 6 AND [pixel] <= 10)
> COLOR 255 0 0
> END
> END
> END
> > From: Christopher Condit [mailto:condit at sdsc.edu]
> > Sent: Friday, May 05, 2006 5:59 PM
> > To: Chris Garrard; MAPSERVER-USERS at LISTS.UMN.EDU
> > Subject: RE: [UMN_MAPSERVER-USERS] displaying rasters with
> > Hi Chris-
> > Can you send your map file? I've had great success with
> > negative raster
> > values when defining my own classes (Sea temperature GeoTIFF
> > / AAI Grid,
> > for instance).
> > -Chris
> > Sent: Friday, May 05, 2006 5:16 PM
> > Subject: [UMN_MAPSERVER-USERS] displaying rasters with
> negative pixel
> > values
> > Hi all,
> > I have a raster data set that has values from -7 to 10 (mean minimum
> > temps C). I can't get any of the pixels with values less than -1 to
> > display in mapserver. I have tried using the processing
> directive to
> > scale the values and I've tried specifying classes, and
> neither works.
> > I have also tried different file formats (geotiffs and erdas .img).
> > Anyone know why this isn't working?
> > I'm using mapserver 4.8.3 and gdal 1.3.1 on solaris 10.
> > Thanks for any ideas,
> > Chris
