AW: [UMN_MAPSERVER-USERS] compiling error mapserver 4.2 under
SLES 9
Manfred Meier
m.meier at SPIEKERMANN.DE
Wed May 17 06:14:37 EDT 2006
Hello,
no, sorry.
In your link list are maplexer.o and mapparser.o. So I'm not sure if you
need flex at all, sorry.
Are you sure libmap.a is there and is the only version on your system?
Manfred
Jens Dahnken schrieb:
> The correct flex library installed, but doesn't solve the problem!
> Any further ideas?
> Thx,
> Jens
> \> \Jens Dahnken schrieb:
> \> \> I'm trying to compile the mapserver 4.2.0 under SLES 9.
> \> \> I call ./configure and that runs through to Makefile.
> \> \> Starting make it ends with:
> \> \> collect2: ld returned 1 exit status
> \> \> make: *** [shp2img] Error 1
> \> \> Any idea how to solve this problem?
> \> \> The whole make protocol is attached.
> \> \> Thanks in advance,
> \> \> Jens
> \> \> Jens Dahnken
> \> \> BT-GIS
> \> \> Bonn
> \> \> make
> \> \> gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF
> \> \> -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT
> \> \> -I/usr/include maptemplate.c -o maptemplate.o
> \> \> -I/usr/include mapbits.c -o mapbits.o
> \> \> -I/usr/include maphash.c -o maphash.o
> \> \> -I/usr/include mapshape.c -o mapshape.o
> \> \> -I/usr/include mapxbase.c -o mapxbase.o
> \> \> -I/usr/include mapparser.c -o mapparser.o
> \> \> -I/usr/include maplexer.c -o maplexer.o
> \> \> -I/usr/include maptree.c -o maptree.o
> \> \> -I/usr/include mapsearch.c -o mapsearch.o
> \> \> -I/usr/include mapstring.c -o mapstring.o
> \> \> -I/usr/include mapsymbol.c -o mapsymbol.o
> \> \> mapsymbol.c: In function `msCopySymbolSet':
> \> \> mapsymbol.c:785: warning: implicit declaration of function
> \> \> `copyStringPropertyRealloc'
> \> \> -I/usr/include mapfile.c -o mapfile.o
> \> \> -I/usr/include maplegend.c -o maplegend.o
> \> \> -I/usr/include maputil.c -o maputil.o
> \> \> -I/usr/include mapscale.c -o mapscale.o
> \> \> -I/usr/include mapquery.c -o mapquery.o
> \> \> -I/usr/include maplabel.c -o maplabel.o
> \> \> -I/usr/include maperror.c -o maperror.o
> \> \> -I/usr/include mapprimitive.c -o mapprimitive.o
> \> \> -I/usr/include mapproject.c -o mapproject.o
> \> \> mapproject.c: In function `msGetEPSGProj':
> \> \> mapproject.c:460: warning: return makes pointer from integer without a
> \> \cast
> \> \> mapproject.c: At top level:
> \> \> mapproject.c:469: warning: `msProjFinder' defined but not used
> \> \> -I/usr/include mapraster.c -o mapraster.o
> \> \> mapraster.c: In function `readGEOTiff':
> \> \> mapraster.c:417: warning: dereferencing type-punned pointer will break
> \> \> strict-aliasing rules
> \> \> mapraster.c:417: warning: passing arg 1 of `TIFFSwabLong' from
> \> \incompatible
> \> \> pointer type
> \> \> mapraster.c:421: warning: dereferencing type-punned pointer will break
> \> \> mapraster.c:421: warning: passing arg 1 of `TIFFSwabLong' from
> \> \incompatible
> \> \> pointer type
> \> \> -I/usr/include mapsde.c -o mapsde.o
> \> \> g++ -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF
> \> \> -I/usr/include mapogr.cpp -o mapogr.o
> \> \> -I/usr/include mappostgis.c -o mappostgis.o
> \> \> -I/usr/include mapmygis.c -o mapmygis.o
> \> \> -I/usr/include maplayer.c -o maplayer.o
> \> \> -I/usr/include mapresample.c -o mapresample.o
> \> \> -I/usr/include mapwms.c -o mapwms.o
> \> \> -I/usr/include mapwmslayer.c -o mapwmslayer.o
> \> \> mapwmslayer.c:128: warning: `msSetWMSParamString' defined but not used
> \> \> mapwmslayer.c:151: warning: `msSetWMSParamInt' defined but not used
> \> \> -I/usr/include maporaclespatial.c -o maporaclespatial.o
> \> \> -I/usr/include mapgml.c -o mapgml.o
> \> \> -I/usr/include mapprojhack.c -o mapprojhack.o
> \> \> mapprojhack.c:71: warning: `ConvertProjUnitStringToMS' defined but not
> \> \used
> \> \> -I/usr/include mapthread.c -o mapthread.o
> \> \> -I/usr/include mapdraw.c -o mapdraw.o
> \> \> mapdraw.c: In function `msDrawMap':
> \> \> mapdraw.c:107: warning: unused variable `lastconnectiontype'
> \> \> -I/usr/include mapgd.c -o mapgd.o
> \> \> -I/usr/include mapoutput.c -o mapoutput.o
> \> \> -I/usr/include mapgdal.c -o mapgdal.o
> \> \> -I/usr/include mapswf.c -o mapswf.o
> \> \> -I/usr/include mapimagemap.c -o mapimagemap.o
> \> \> mapimagemap.c:58: warning: `searchImageCache' defined but not used
> \> \> mapimagemap.c:94: warning: `addImageCache' defined but not used
> \> \> mapimagemap.c:347: warning: `imageOffsetPolyline' defined but not used
> \> \> mapimagemap.c:378: warning: `imagePolyline' defined but not used
> \> \> mapimagemap.c:1414: warning: `billboardIM' defined but not used
> \> \> -I/usr/include mapows.c -o mapows.o
> \> \> -I/usr/include mapwfs.c -o mapwfs.o
> \> \> -I/usr/include mapwfslayer.c -o mapwfslayer.o
> \> \> -I/usr/include mapcontext.c -o mapcontext.o
> \> \> -I/usr/include maphttp.c -o maphttp.o
> \> \> -I/usr/include mapdrawgdal.c -o mapdrawgdal.o
> \> \> -I/usr/include mappdf.c -o mappdf.o
> \> \> -I/usr/include mapjoin.c -o mapjoin.o
> \> \> -I/usr/include mapgraticule.c -o mapgraticule.o
> \> \> -I/usr/include mapcopy.c -o mapcopy.o
> \> \> mapcopy.c: In function `msCopyProjection':
> \> \> mapcopy.c:103: warning: unused variable `i'
> \> \> -I/usr/include mapogcfilter.c -o mapogcfilter.o
> \> \> -I/usr/include mapogcsld.c -o mapogcsld.o
> \> \> -I/usr/include maptime.c -o maptime.o
> \> \> maptime.c: In function `msStrptime':
> \> \> maptime.c:92: warning: implicit declaration of function `strptime'
> \> \> maptime.c:92: warning: return makes pointer from integer without a
> \cast
> \> \> -I/usr/include mapwcs.c -o mapwcs.o
> \> \> -I/usr/include cgiutil.c -o cgiutil.o
> \> \> -I/usr/include epplib.c -o epplib.o
> \> \> ar rc libmap.a maptemplate.o mapbits.o maphash.o mapshape.o mapxbase.o
> \> \> mapparser.o maplexer.o maptree.o mapsearch.o mapstring.o mapsymbol.o
> \> \> mapfile.o maplegend.o maputil.o mapscale.o mapquery.o maplabel.o
> \> \maperror.o
> \> \> mapprimitive.o mapproject.o mapraster.o mapsde.o mapogr.o mappostgis.o
> \> \> mapmygis.o maplayer.o mapresample.o mapwms.o mapwmslayer.o
> \> \> maporaclespatial.o mapgml.o mapprojhack.o mapthread.o mapdraw.o
> \mapgd.o
> \> \> mapoutput.o mapgdal.o mapswf.o mapimagemap.o mapows.o mapwfs.o
> \> \mapwfslayer.o
> \> \> mapcontext.o maphttp.o mapdrawgdal.o mappdf.o mapjoin.o mapgraticule.o
> \> \> mapcopy.o mapogcfilter.o mapogcsld.o maptime.o mapwcs.o cgiutil.o
> \> \epplib.o
> \> \> ranlib libmap.a
> \> \> -I/usr/include shp2img.c -o shp2img.o
> \> \> gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -
> \> \DUSE_JPEG
> \> \> -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -
> \> \I/usr/include
> \> \> shp2img.o -L. -lmap -lgd -L/usr/lib -lgd -ljpeg -lfreetype -lz -
> \> \ltiff
> \> \> -ljpeg -lfreetype -lz -ljpeg -lm -lstdc++ -o shp2img
> \> \> ./libmap.a(mapfile.o)(.text+0x9d6): In function `getCharacter':
> \> \> : undefined reference to `msyylex'
> \> \> ./libmap.a(mapfile.o)(.text+0x9e2): In function `getCharacter':
> \> \> : undefined reference to `msyytext'
> \> \> ./libmap.a(mapfile.o)(.text+0x9f5): In function `getCharacter':
> \> \> : undefined reference to `msyylineno'
> \> \> ./libmap.a(mapfile.o)(.text+0x9fb): In function `getCharacter':
> \> \> ./libmap.a(mapfile.o)(.text+0xa26): In function `getInteger':
> \> \> ./libmap.a(mapfile.o)(.text+0xa43): In function `getInteger':
> \> \> : undefined reference to `msyynumber'
> \> \> ./libmap.a(mapfile.o)(.text+0xa57): In function `getInteger':
> \> \> ./libmap.a(mapfile.o)(.text+0xa5d): In function `getInteger':
> \> \> ./libmap.a(mapfile.o)(.text+0xa86): In function `getDouble':
> \> \> ./libmap.a(mapfile.o)(.text+0xa96): In function `getDouble':
> \> \> ./libmap.a(mapfile.o)(.text+0xa9c): In function `getDouble':
> \> \> ./libmap.a(mapfile.o)(.text+0xaae): In function `getDouble':
> \> \> ./libmap.a(mapfile.o)(.text+0xab5): In function `getDouble':
> \> \> ./libmap.a(mapfile.o)(.text+0xbed): In function `loadColor':
> \> \> ./libmap.a(mapfile.o)(.text+0xcb6): In function `getToken':
> \> \> ./libmap.a(mapfile.o)(.text+0xcbe): In function `getToken':
> \> \> ./libmap.a(mapfile.o)(.text+0xcd6): In function `getString':
> \> \> ./libmap.a(mapfile.o)(.text+0xce6): In function `getString':
> \> \> ./libmap.a(mapfile.o)(.text+0xcf6): In function `getString':
> \> \> ./libmap.a(mapfile.o)(.text+0xcfc): In function `getString':
> \> \> ./libmap.a(mapfile.o)(.text+0x34d6): In function `msCleanup':
> \> \> : undefined reference to `lexer_cleanup'
> \> \> ./libmap.a(mapfile.o)(.text+0x3b16): In function `loadHashTable':
> \> \> ./libmap.a(mapfile.o)(.text+0x3b54): In function `loadHashTable':
> \> \> ./libmap.a(mapfile.o)(.text+0x3b74): In function `loadHashTable':
> \> \> ./libmap.a(mapfile.o)(.text+0x3b7b): In function `loadHashTable':
> \> \> ./libmap.a(mapfile.o)(.text+0x3c01): In function `loadWeb':
> \> \> ./libmap.a(mapfile.o)(.text+0x3e04): In function `loadWeb':
> \> \> ./libmap.a(mapfile.o)(.text+0x3e0a): In function `loadWeb':
> \> \> ./libmap.a(mapfile.o)(.text+0x48ff): In function `getSymbol':
> \> \> ./libmap.a(mapfile.o)(.text+0x4924): In function `getSymbol':
> \> \> ./libmap.a(mapfile.o)(.text+0x492b): In function `getSymbol':
> \> \> ./libmap.a(mapfile.o)(.text+0x4960): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x497d): In function `loadLabelString':
> \> \> : undefined reference to `msyystate'
> \> \> ./libmap.a(mapfile.o)(.text+0x4987): In function `loadLabelString':
> \> \> : undefined reference to `msyystring'
> \> \> ./libmap.a(mapfile.o)(.text+0x49b3): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x49bd): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x49d1): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x49db): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x49ff): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x4a09): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x4a20): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x4a2a): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x4a72): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x4a7c): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x4aa3): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x4aad): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x4ac2): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x4acc): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x4b0e): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x4b4c): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x4b56): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x4b73): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x4b87): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x4bcd): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x4bd7): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x4c04): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x4c0e): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x4c4a): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x4c54): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x4c83): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x4c89): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x4cad): In function `loadLabelString':
> \> \> ./libmap.a(mapfile.o)(.text+0x4cc9): In function `loadQueryMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x4d98): In function `loadLabel':
> \> \> ./libmap.a(mapfile.o)(.text+0x4e26): In function `loadLabel':
> \> \> ./libmap.a(mapfile.o)(.text+0x5033): In function `loadLabel':
> \> \> ./libmap.a(mapfile.o)(.text+0x5039): In function `loadLabel':
> \> \> ./libmap.a(mapfile.o)(.text+0x505d): In function `loadLabel':
> \> \> ./libmap.a(mapfile.o)(.text+0x51a7): In function `loadLabel':
> \> \> ./libmap.a(mapfile.o)(.text+0x51bb): In function `loadLabel':
> \> \> ./libmap.a(mapfile.o)(.text+0x51c2): In function `loadLabel':
> \> \> ./libmap.a(mapfile.o)(.text+0x5211): In function `loadScalebar':
> \> \> ./libmap.a(mapfile.o)(.text+0x527e): In function `loadScalebar':
> \> \> ./libmap.a(mapfile.o)(.text+0x5485): In function `loadScalebar':
> \> \> ./libmap.a(mapfile.o)(.text+0x548c): In function `loadScalebar':
> \> \> ./libmap.a(mapfile.o)(.text+0x54d2): In function `loadLegend':
> \> \> ./libmap.a(mapfile.o)(.text+0x5542): In function `loadLegend':
> \> \> ./libmap.a(mapfile.o)(.text+0x56cf): In function `loadLegend':
> \> \> ./libmap.a(mapfile.o)(.text+0x56d6): In function `loadLegend':
> \> \> ./libmap.a(mapfile.o)(.text+0x5731): In function `loadReferenceMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x5788): In function `loadReferenceMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x587f): In function `loadReferenceMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x5896): In function `loadReferenceMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x592c): In function `loadReferenceMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x5932): In function `loadReferenceMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x59a9): In function `loadStyle':
> \> \> ./libmap.a(mapfile.o)(.text+0x5a02): In function `loadStyle':
> \> \> ./libmap.a(mapfile.o)(.text+0x5adf): In function `loadStyle':
> \> \> ./libmap.a(mapfile.o)(.text+0x5af5): In function `loadStyle':
> \> \> ./libmap.a(mapfile.o)(.text+0x5b58): In function `loadStyle':
> \> \> ./libmap.a(mapfile.o)(.text+0x5b5e): In function `loadStyle':
> \> \> ./libmap.a(mapfile.o)(.text+0x5bab): In function
> \`loadExpressionString':
> \> \> ./libmap.a(mapfile.o)(.text+0x5bbb): In function
> \> \> ./libmap.a(mapfile.o)(.text+0x5be7): In function
> \> \> ./libmap.a(mapfile.o)(.text+0x5c19): In function
> \> \> ./libmap.a(mapfile.o)(.text+0x5c7f): In function `loadExpression':
> \> \> ./libmap.a(mapfile.o)(.text+0x5cc2): In function `loadClass':
> \> \> ./libmap.a(mapfile.o)(.text+0x5d36): In function `loadClass':
> \> \> ./libmap.a(mapfile.o)(.text+0x5e0b): In function `loadClass':
> \> \> ./libmap.a(mapfile.o)(.text+0x5e95): In function `loadClass':
> \> \> ./libmap.a(mapfile.o)(.text+0x60b5): In function `loadClass':
> \> \> ./libmap.a(mapfile.o)(.text+0x6106): In function `loadClass':
> \> \> ./libmap.a(mapfile.o)(.text+0x6260): In function `loadClass':
> \> \> ./libmap.a(mapfile.o)(.text+0x6267): In function `loadClass':
> \> \> ./libmap.a(mapfile.o)(.text+0x62f5): In function `loadJoin':
> \> \> ./libmap.a(mapfile.o)(.text+0x63fd): In function `loadJoin':
> \> \> ./libmap.a(mapfile.o)(.text+0x6403): In function `loadJoin':
> \> \> ./libmap.a(mapfile.o)(.text+0x64b7): In function `loadLayer':
> \> \> ./libmap.a(mapfile.o)(.text+0x657c): In function `loadLayer':
> \> \> ./libmap.a(mapfile.o)(.text+0x686e): In function `loadLayer':
> \> \> ./libmap.a(mapfile.o)(.text+0x68d0): In function `loadLayer':
> \> \> ./libmap.a(mapfile.o)(.text+0x6901): In function `loadLayer':
> \> \> ./libmap.a(mapfile.o)(.text+0x6c4c): In function `loadLayer':
> \> \> ./libmap.a(mapfile.o)(.text+0x6d38): In function `loadLayer':
> \> \> ./libmap.a(mapfile.o)(.text+0x6d3f): In function `loadLayer':
> \> \> ./libmap.a(mapfile.o)(.text+0x6f00): In function `loadLayer':
> \> \> ./libmap.a(mapfile.o)(.text+0x6f06): In function `loadLayer':
> \> \> ./libmap.a(mapfile.o)(.text+0x6fca): In function `loadLayer':
> \> \> ./libmap.a(mapfile.o)(.text+0x6fd0): In function `loadLayer':
> \> \> ./libmap.a(mapfile.o)(.text+0x7015): In function `loadLayer':
> \> \> ./libmap.a(mapfile.o)(.text+0x701c): In function `loadLayer':
> \> \> ./libmap.a(mapfile.o)(.text+0x719e): In function `msTokenizeMap':
> \> \> : undefined reference to `msyyin'
> \> \> ./libmap.a(mapfile.o)(.text+0x71c9): In function `msTokenizeMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x71d2): In function `msTokenizeMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x71da): In function `msTokenizeMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x71e7): In function `msTokenizeMap':
> \> \> : undefined reference to `msyyrestart'
> \> \> ./libmap.a(mapfile.o)(.text+0x71ed): In function `msTokenizeMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x721b): In function `msTokenizeMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x725e): In function `msTokenizeMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x7286): In function `msTokenizeMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x72a8): In function `msTokenizeMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x72c4): In function `msTokenizeMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x72ea): In function `msTokenizeMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x730c): In function `msTokenizeMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x7332): more undefined references to
> \> \`msyytext'
> \> \> follow
> \> \> ./libmap.a(mapfile.o)(.text+0x7361): In function `msTokenizeMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x7390): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x73a9): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x73b3): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x73ee): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x7435): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x743f): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x745c): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x7466): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x7484): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x7493): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x749e): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x74b2): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x74bf): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x74ca): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x74d9): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x74e3): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x75a1): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x75ab): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x75ea): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x75fe): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x7608): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x7625): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x765c): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x7671): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x7683): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x768d): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x76ab): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x76c3): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x76cd): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x76f9): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x770b): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x7722): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x775b): In function `loadClassString':
> \> \> ./libmap.a(mapfile.o)(.text+0x77c3): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x787b): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x7885): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x7983): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x798d): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x7a92): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x7b2d): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x7b37): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x7c13): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x7c61): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x7c67): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x7c92): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x7c9c): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x7d08): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x7d12): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x7d29): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x7d33): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x7db6): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x7ddc): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8010): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x801a): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x807d): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8087): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x80b0): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x80ba): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x80ea): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x80f4): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x812a): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8134): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x815c): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8166): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x821e): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8228): In function `loadLayerString':
> \> \> ./libmap.a(mapfile.o)(.text+0x833b): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8347): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8359): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8366): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x836f): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8386): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x83da): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x83e8): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8497): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x84a1): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x854b): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8559): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8601): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x866a): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8697): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x86a1): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8739): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x87aa): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x87d9): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x87e3): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x882f): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x886a): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8874): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8896): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x88a0): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x88b7): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x88c1): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8955): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x895f): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x89f9): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8a03): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8a9c): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8aed): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8af7): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8b45): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8b4f): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8b8d): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8b97): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8c7e): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8c88): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8cc4): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8cfc): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8d06): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8d76): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8d80): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8d97): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8da1): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8deb): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8df4): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8e18): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8e22): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8e4f): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8e5b): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8ea2): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8eac): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8ee5): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8eef): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8f22): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8f2b): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8f42): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8f4b): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8f6e): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8f78): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8fa4): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8fad): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8fc8): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8fd2): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x8ffc): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x9006): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x9038): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x9042): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x9071): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x907b): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x9094): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x909f): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x90eb): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x90f5): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x910f): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x9119): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x9132): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x913e): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x9162): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x916c): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x91a8): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x91b6): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x922d): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x9237): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x9259): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x9263): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x9298): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x92a2): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x92df): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x92e9): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x9385): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x938e): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x93d2): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x93db): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x9450): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x945a): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x9480): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x948a): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x94a0): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x94a9): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x94cb): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x94d9): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x94f4): In function `msLoadMapString':
> \> \> ./libmap.a(mapfile.o)(.text+0x95ab): In function `msLoadMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x95f4): In function `msLoadMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x95fd): In function `msLoadMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x9606): In function `msLoadMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x960c): In function `msLoadMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x9619): In function `msLoadMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x9684): In function `msLoadMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x976d): In function `msLoadMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x9a47): In function `msLoadMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x9aa0): In function `msLoadMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x9fab): In function `msLoadMap':
> \> \> ./libmap.a(mapfile.o)(.text+0x9fb2): In function `msLoadMap':
> \> \> ./libmap.a(mapfile.o)(.text+0xa20d): In function `msLoadMap':
> \> \> ./libmap.a(mapfile.o)(.text+0xa43d): In function `msLoadMap':
> \> \> ./libmap.a(mapfile.o)(.text+0xa444): In function `msLoadMap':
> \> \> ./libmap.a(mapfile.o)(.text+0xa458): In function `msLoadMap':
> \> \> ./libmap.a(mapfile.o)(.text+0xa45e): In function `msLoadMap':
> \> \> ./libmap.a(mapfile.o)(.text+0xa4dc): In function `msLoadMap':
> \> \> ./libmap.a(mapfile.o)(.text+0xa4e2): In function `msLoadMap':
> \> \> ./libmap.a(maputil.o)(.text+0x1a32): In function `msEvalExpression':
> \> \> ./libmap.a(maputil.o)(.text+0x1a3c): In function `msEvalExpression':
> \> \> ./libmap.a(maputil.o)(.text+0x1cc1): In function `msEvalContext':
> \> \> ./libmap.a(maputil.o)(.text+0x1cd1): In function `msEvalContext':
> \> \> ./libmap.a(mapparser.o)(.text+0x50b): In function `msyyparse':
> \> \> : undefined reference to `msyyerror'
> \> \> ./libmap.a(mapparser.o)(.text+0xa94): In function `msyyparse':
> \> \> ./libmap.a(mapparser.o)(.text+0xabe): In function `msyyparse':
> \> \> ./libmap.a(mapparser.o)(.text+0xbd5): In function `msyyparse':
> \> \> ./libmap.a(mapsymbol.o)(.text+0xf29): In function `loadSymbol':
> \> \> ./libmap.a(mapsymbol.o)(.text+0xf7f): In function `loadSymbol':
> \> \> ./libmap.a(mapsymbol.o)(.text+0x1014): In function `loadSymbol':
> \> \> ./libmap.a(mapsymbol.o)(.text+0x1042): In function `loadSymbol':
> \> \> ./libmap.a(mapsymbol.o)(.text+0x11ac): In function `loadSymbol':
> \> \> ./libmap.a(mapsymbol.o)(.text+0x11d6): In function `loadSymbol':
> \> \> ./libmap.a(mapsymbol.o)(.text+0x12fa): In function `loadSymbol':
> \> \> ./libmap.a(mapsymbol.o)(.text+0x1313): In function `loadSymbol':
> \> \> ./libmap.a(mapsymbol.o)(.text+0x1342): In function `loadSymbol':
> \> \> ./libmap.a(mapsymbol.o)(.text+0x13e4): In function `loadSymbol':
> \> \> ./libmap.a(mapsymbol.o)(.text+0x13ea): In function `loadSymbol':
> \> \> ./libmap.a(mapsymbol.o)(.text+0x1405): In function `loadSymbol':
> \> \> ./libmap.a(mapsymbol.o)(.text+0x148c): In function `loadSymbol':
> \> \> ./libmap.a(mapsymbol.o)(.text+0x1493): In function `loadSymbol':
> \> \> ./libmap.a(mapsymbol.o)(.text+0x154f): In function `loadSymbol':
> \> \> ./libmap.a(mapsymbol.o)(.text+0x1556): In function `loadSymbol':
> \> \> ./libmap.a(mapsymbol.o)(.text+0x156e): In function `loadSymbol':
> \> \> ./libmap.a(mapsymbol.o)(.text+0x160f): In function `msLoadSymbolSet':
> \> \> ./libmap.a(mapsymbol.o)(.text+0x1626): In function `msLoadSymbolSet':
> \> \> ./libmap.a(mapsymbol.o)(.text+0x1632): In function `msLoadSymbolSet':
> \> \> ./libmap.a(mapsymbol.o)(.text+0x1638): In function `msLoadSymbolSet':
> \> \> ./libmap.a(mapsymbol.o)(.text+0x164c): In function `msLoadSymbolSet':
> \> \> ./libmap.a(mapsymbol.o)(.text+0x1655): In function `msLoadSymbolSet':
> \> \> ./libmap.a(mapsymbol.o)(.text+0x1674): In function `msLoadSymbolSet':
> \> \> ./libmap.a(mapsymbol.o)(.text+0x16d4): In function `msLoadSymbolSet':
> \> \> ./libmap.a(mapraster.o)(.text+0xe7f): In function `msGetClass_Float':
> \> \> ./libmap.a(mapraster.o)(.text+0xe8a): In function `msGetClass_Float':
> \> \> ./libmap.a(mapraster.o)(.text+0x1186): In function `msGetClass':
> \> \> ./libmap.a(mapraster.o)(.text+0x1191): In function `msGetClass':
> \> \No virus found in this incoming message.
> \> \Checked by AVG Free Edition.
> \> \Version: 7.1.392 / Virus Database: 268.6.0/341 - Release Date:
> \16.05.2006
> \Version: 7.1.392 / Virus Database: 268.6.0/341 - Release Date: 16.05.2006
