how to use pictures as labels
Hal Mueller
hal at MOBILEGEOGRAPHICS.COM
Tue Nov 7 03:16:05 EST 2006
Are the surrounding labels data-dependent? Or is there a small
number of states?
One way to approach this is to pre-render the point icon plus
"labels", and use that image as the icon for your plot.
Another way to do it would be to have 5 different layers, one for
each of the different images. The trick is that for the 4 layers
representing the layers, you use a large icon, but with the image
off-centered. That is, make 4 copies of your "image 2". In each
copy, delete the red circle. In copy one, delete all but the green
rectangle. In copy two, delete all but the purple diamond.
Hal
