Antwort: Re: [UMN_MAPSERVER-USERS] Blank Image OracleSpatial
Benedikt Rothe
umn-ms at HYDROTEC.DE
Thu Nov 23 07:24:37 EST 2006
What about the SRID? Is it set in Oracle-Metada?
You may query it in SQL+ with
select table_name,srid from user_sdo_geom_metadata where
table_name='RED_FERROCARRIL'
(or
select "OWNER", table_name, srid from user_sdo_geom_metadata where
table_name='RED_FERROCARRIL')
UMN MapServer Users List <MAPSERVER-USERS at LISTS.UMN.EDU> schrieb am
23.11.2006 12:50:34:
> if I execute that, it does not give back anything , and the following
message;
> SQL> SELECT rownum, SHAPE FROM RED_FERROCARRIL WHERE SDO_FILTER( SHAPE,
MDSYS.SDO_GEOMETRY(2003,
> L,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),
MDSYS.SDO_ORDINATE_ARRAY(-206.756757,-170,206.756757
> ) ),'querytype=window') = 'TRUE;
> ninguna fila seleccionada
> no selected row in english or something similar
> I supposed that it was for that reason, but either like correcting it;
> what can i do?
> 2006/11/23, umn-ms at hydrotec.de <umn-ms at hydrotec.de>:
> Hi
> * Does the logged SQL-Statement produce any output if you
> execute it in SQL+?
> * Did you specify an SRID in Spatial-Metadata? Than you have to specify
it
> in the mapfile to.
> Benedikt
23.11.2006 09:08:12:
> > Hi People!
> > I have installed MS4W for Windows, with maplab, chamaleon, php 4.4.2
> > I am with problems when I make a request on layer lodged in a oracle
data base, because always shows a blank image.
> > Im using Oracle 9i and Spatial. The dlls are in dlls their
corresponding directories. If I make a request on a layer lodged in a data
file, this is is correctly.
> > Im using oraclespatial method , not by OCI.
> > In error.log file it appears:
> > [error] [client 172.21.128.99] msOracleSpatialLayerOpen called with:
SHAPE FROM RED_FERROCARRIL USING VERSION 9i\r
> > [error] [client 172.21.128.99] msOracleSpatialLayerOpen. Shared
connection not available. Creating one.\r
msConnPoolRegister(ferrocarriles,sde/sde at SDE,01912370)\r
> > [error] [client 172.21.128.99] msOracleSpatialLayerFreeItemInfo was
called.\r
> > [error] [client 172.21.128.99] msOracleSpatialLayerWhichShapes was
called.\r
> > [[error] [client 172.21.128.99] msOracleSpatialLayerWhichShapes. Using
this Sql to retrieve the data: SELECT rownum, SHAPE FROM RED_FERROCARRIL
WHERE SDO_FILTER( SHAPE, MDSYS.SDO_GEOMETRY (2003, NULL,
NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(-206.756757,-170,206.756757,170)
),'querytype=window') = 'TRUE'\r
called.\r
> > [error] [client 172.21.128.99] msOracleSpatialLayerClose was called.
Layer connection: sde/sde at SDE\r
> > [error] [client 172.21.128.99] msOracleSpatialLayerClose. Cleaning
layerinfo handlers.\r
Oracle handlers.\r
> > [error] [client 172.21.128.99] msConnPoolRelease(ferrocarriles,
> > [error] [client 172.21.128.99] msConnPoolClose(sde/sde at SDE,01912370)\r
> > [error] [client 172.21.128.99] msDrawMap(): Layer 2 (ferrocarriles),
0.218s\r
> > Thxs
> > José Ramón López
> José Ramón López
> Tfno: 627 88 88 24
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061123/e1832c66/attachment.html
