I need the ability to be able to display ECW and JPEG2000
format files within MapServer via a Community Mapbuilder client
which sends WMS requests for the images to MapServer
John Mitchell
mitchelljj98 at GMAIL.COM
Fri Nov 24 06:46:33 EST 2006
Hi Frank,
Thanks for the information. I had a couple of questions:
You said below:
I am using the "standalone" FWTools binaries for linux
(http://fwtools.maptools.org). In my Apache cgi-bin directory I have
the script mapserv_landsat which looks like this:
#!/bin/sh
export MS_MAPFILE=/home/warmerda/maps/landsat.map
. /opt/FWTools-1.0.0a2/fwtools_env.sh
exec /opt/FWTools-1.0.0a2/bin/mapserv "$*"
How would the above be revised on a windows system? The exec statement I
would replace the /opt with /program files since FWTools is within the
"program files" folder on windows. What about the
. /opt/FWTools-1.0.0a2/fwtools_env.sh statement? I don't see anything
called fwtools_env.sh within the FWTools folder. What is #!/bin/sh is this
a linux statement?
Thanks,
John J. Mitchell
On 11/23/06, Frank Warmerdam <warmerdam at pobox.com> wrote:
> John Mitchell wrote:
> > Hi,
> > I need the ability to be able to display ECW and JPEG2000 format files
> > within MapServer via a Community Mapbuilder client which sends WMS
> > requests for the images to MapServer. My current architecture is
> > PostGreSQL database connected to PostGIS which connects to GeoServer on
> > Apache Tomcat and Community Mapbuilder client which sends WMS requests
> > for the images to GeoServer. I would like to be able to send similar
> > requests to MapServer for compressed Raster data but instead of going to
> > PostGIS I would like to connect to the ECW (which are compressed Raster)
> > files and JPEG2000 files.
> > Since I have never installed or used MapServer before I would appreciate
> > it if someone could give my a high level overview of what I would need
> > to do as far as:
> > 1.) What should I download for a windows server if all I want to do is
> > display ECW and JPEG2000 files via WMS?
> > 2.) What configuration is necessary on the server in order to display
> > via WMS for ECW and JPEG2000 files and what location should I place
> > these files?
> > 3.) What is the format for both a GetMap and GetCapabilities request on
> > the client side which in my case is Community Mapbuilder.
> John,
> You don't specify what platform you want to deploy on. The trick with
> JPEG2000 and ECW support is getting a binary build for your platform that
> has these formats included.
> I have a service at http://maps.gdal.org serving a big south american
> landsat scene from ecw. I'll provide details on my configuration. You
> may find it helpful to take a similar approach.
> #!/bin/sh
> This basically invokes the FWTools mapserver executable with a
> preconfigured mapfile. The FWTools binaries include essentially all
> required libraries. The mapfile looks like the following and includes
> sufficient metadat to serve via WMS and WCS. I think there may be a
> bit of extra cruft in there too.
> MAP
> NAME 'LANDSAT'
> EXTENT -180 -90 180 90
> UNITS DD
> SIZE 600 300
> IMAGECOLOR 0 255 0
> IMAGETYPE JPEG
> DEBUG ON
> PROJECTION
> "init=epsg:4326"
> END
> OUTPUTFORMAT
> NAME jpeg2000
> DRIVER "GDAL/JP2ECW"
> MIMETYPE "image/jpeg2000"
> FORMATOPTION "TARGET=95"
> IMAGEMODE RGB
> END
> # Start of web interface definition
> WEB
> HEADER web/landsatcgi/demo_header.html
> TEMPLATE web/landsatcgi/demo.html
> FOOTER web/landsatcgi/demo_footer.html
> METADATA
> "ows_title" "Landsat Server"
> "wcs_label" "Landsat WCS Server"
> "wcs_keywordlist" "WCS,Landsat"
> "wcs_onlineresource" "http://maps.gdal.org/cgi-bin/mapserv_landsat"
> END
> IMAGEURL "/tmp/"
> IMAGEPATH "/u/maps/tmp/"
> END
> LAYER
> NAME "South America"
> STATUS ON
> DEBUG ON
> TYPE RASTER
> DATA '/home/warmerda/torrents/data/South America Landsat742.ecw'
> METADATA
> wcs_label "Landsat"
> ows_title "Landsat"
> ows_srs "EPSG:4269 EPSG:4326"
> ows_extent "-82.3512420 -56.8510672 -33.9029540 13.0499433"
> wcs_resolution "0.00025602 0.00025602"
> wcs_formats "JPEG PNG24"
> wcs_nativeformat "ECW"
> END
> DUMP TRUE
> PROJECTION
> "init=epsg:4326"
> END
> END
> END
> Note that to use an ecw file (or jpeg2000 file) you just specify the
> name in the DATA line for the layer.
> The getcapabilities url for my service is:
> http://maps.gdal.org/cgi-bin/mapserv_landsat?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities
> I hope this helps.
> Good luck,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
John J. Mitchell
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061124/f0c248f5/attachment.html
