How to use MySQL Server with MyGIS?
YuGo
yu.gotou at GTEC-NI.COM
Fri Nov 24 22:30:57 EST 2006
Hi everybody,
I compiled Mapserver-4.10.0 with MyGIS.
I excuted this sql on MySQL Sever
create table geomtbl (id int auto_increment primary key,geom geometry);
insert into geomtbl (geom) values(geomfromtext('POINT(15 15)'));
I create this .map file
MAP
IMAGETYPE png
EXTENT 0 0 30 30
SIZE 800 600
SHAPEPATH "."
UNITS meters
LAYER
name geomtest
CONNECTIONTYPE mygis
CONNECTION "localhost:root:password:test:bin:"
DATA "geom from geomtbl geometry"
TYPE POINT
STATUS default
CLASS
name geomtest
COLOR 255 255 0
END
END
END
and request url via cgi ,but results is
msDrawMap(): Image handling error. Failed to draw layer named 'geomtest'.
msMYGISLayerGetShapeRandom(): Query error. GetShape called on MYGIS layer
with invalid DB query results.
SELECT feature.id, feature.vertices, geometry.WKB_GEOMETRY fro: Query error.
mysql query failed
What's wrong this process?
yu_go
