SOS GetObservation
Sridur
dur.sri at GMAIL.COM
Wed Nov 29 17:40:41 EST 2006
Hi Tom,
Thank you for the reply. Yes, WQ1289 was defined as the sos_offering_id.
Below are the contents of my sos_test.map file (example from
http://mapserver.gis.umn.edu/docs/howto/sos_server/ )
Regards,
Sridur
NAME SOS_DEMO
STATUS ON
SIZE 300 300
EXTENT -66 44 -62 45
UNITS METERS
SHAPEPATH "./data/"
IMAGECOLOR 255 255 0
SYMBOLSET "./etc/symbols.sym"
IMAGETYPE png
WEB
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
"sos_onlineresource"
"http://127.0.0.1/cgi-bin/mapserv.exe?map=/ms4w/apps/sos/sos_test.map" ##
REQUIRED
"sos_title" "My SOS Demo Server" ## Recommended
"sos_srs" "epsg:4326" ## Recommended
END
END
PROJECTION
"init=epsg:4326"
END
LAYER
NAME test_sos_layer
METADATA
"sos_procedure" "NS01EE0014" ## REQUIRED
"sos_offering_id" "WQ1289" ## REQUIRED
"sos_observedproperty_id" "WaterQuality" ## REQUIRED
"sos_describesensor_url" "http://some/url/NS01EE0014.xml" ## REQUIRED
END
TYPE POINT
STATUS ON
DATA sos_test
PROJECTION
"init=epsg:4326"
END
CLASS
NAME "water quality"
STYLE
COLOR 255 0 0
SYMBOL "circle"
SIZE 8
END
END
END
END #map
Kralidis,Tom [Burlington] wrote:
>> Hi,
>> I am able to get the GetCapabilties and DescribeSensor
>> requests working correctly
>> (http://mapserver.gis.umn.edu/docs/howto/sos_server/)
>> However, I am not sure how to configure SOS mapfile for
>> GetObservation. I would like to put all my observation values
>> in a database (PostgreSQL) and then be able to retrieve the
>> observation values from it. Can anyone please tell me what
>> all the tables I need to create in the database and also how
>> to configure Mapserver (/mapfile) to retreive the data
>> (observation values) from a request like this:
> st.map&Request=GetObservation&service=SOS&Offering=WQ1289>
> &observedproperty=WaterQuality&version=0.0.31
> In your request URL: I see you have an offering of WQ1289. Did you
> define this as your offering_id in your LAYER/METADATA?
> If you can post a LAYER definition within your mapfile, that would be
> helpful.
> ..Tom
View this message in context: http://www.nabble.com/SOS-GetObservation-tf2727213.html#a7609616
Sent from the Mapserver - User mailing list archive at Nabble.com.
