Variable substitution and WMS
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Tue Oct 3 11:19:48 EDT 2006
You should be able to do so, yes.
The only point to be aware is if a generic client (say I have an
application, for example), who wishes to connect to your OGC:WMS, but is
unaware of the username/password mechanism, will run into problems. If
your OGC:WMS is serving a controlled set of applications exclusively,
then this may not be that big of an issue.
..Tom
> -----Original Message-----
> From: John Cole [mailto:john.cole at uai.com]
> Sent: 03 October, 2006 11:17 AM
> To: Kralidis,Tom [Burlington]; MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: RE: [UMN_MAPSERVER-USERS] Variable substitution and WMS
> Tom,
> We have an asp.net/atlas wrapper that calls out to
> mapserver via CGI. I would like to change that to use WMS.
> If I understand correctly, I should be able to simply add a
> few more parameters to the WMS request string and mapserver
> will use those the same way as a mode=map request and
> substitute them into %var% tags?
> Thanks,
> John
> From: Kralidis,Tom [Burlington] [mailto:Tom.Kralidis at ec.gc.ca]
> Sent: Tuesday, October 03, 2006 10:10 AM
> To: John Cole; MAPSERVER-USERS at LISTS.UMN.EDU
> > From: UMN MapServer Users List
> > [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of John Cole
> > Sent: 03 October, 2006 11:06 AM
> > To: MAPSERVER-USERS at LISTS.UMN.EDU
> > Subject: [UMN_MAPSERVER-USERS] Variable substitution and WMS
> > Is it possible to use variable substitution with a WMS request to
> > mapserver?
> > It would be nice to be able to set username/passwords or other
> > information for layer queries to the mapfile.
> > Thanks,
> > John
> You should be able to use it with OGC:WMS, however a client
> would require more intelligence to pass along those
> variables. i.e. a vanille OGC:WMS client would need to be
> enhanced for this.
> Additionally, you can take a look at the Mapscript WxS
> services capability through you favourite scripting language,
> which can now expose as OGC Web Services (see the MapServer
> OGC Web Services Workshop
> [http://ms-ogc-workshop.maptools.org/] for more info and examples).
> ..Tom
> This email and any files transmitted with it are confidential
> and intended solely for the use of the individual or entity
> to whom they are addressed. If you have received this email
> in error please notify the sender. This message contains
> confidential information and is intended only for the
> individual named. If you are not the named addressee you
> should not disseminate, distribute or copy this e-mail.
