Mapscript adding class with PHP
Murat BEYHAN
beyhan at DEPREM.GOV.TR
Wed Oct 4 02:38:25 EDT 2006
Hi Arie,
please try the following in yor php script,
I'm new on PhpMapscript so. I hope this solve your problem
> $new_class = ms_newClassObj($this_layer);
> $new_class->setExpression('Australia');
> $new_class->set('name','Australia');
$new_class->color->setRGB(255,0,0);////////////////here you should add
> $new_class->label->outlinecolor->setRGB(255,255,255);
> $new_class->label->set(minfeaturesize,40);
regards
Murat
On Tue, 3 Oct 2006 21:35:33 +0200, Arie Mijnlieff wrote
> Hi,
> I want to show countries in my world map based on a form with
> checkboxes.
> If I check Argentina and Australia i would like to show both
> countries in red, whereas the other are in another color. If i
> change the selection in Australia and India i would like Australia
> and India to be red.
> I have a .map file with a layer called countries. In that layer i
> have a class:
> CLASS # Start of CLASS object
> NAME 'Argentina'
> EXPRESSION 'Argentina'
> OUTLINECOLOR 100 100 100
> COLOR 255 255 150
> LABEL
> SIZE LARGE
> OUTLINECOLOR 255 255 255
> MINFEATURESIZE 40
> END
> END # End of CLASS object
> So i thought if Australia is checked, i add a class object to my
> layer using php with the same colors:
> Australia will not be red however. I do not understand how i can
> change the color of my new class. I succeeded only to change the
> color of the label.. What do i do wrong ?
> If i change the color of an existing class i can see that change
> however..
> $my_class = $this_layer->getClass(0);
> $my_class->setExpression('Australia');
> $my_class->set('name','Australia');
> Any help will be appreciated !!
> Arie
> This message has been scanned for viruses and
> dangerous content by MailScanner, and is
> believed to be clean.
Open WebMail Project (http://openwebmail.org)
