mapserver-4.10.0-rc1
davidvaz davidvaz at NCC.UP.PT
Wed Oct 4 13:24:54 EDT 2006
Daniel Morissette wrote:
> davidvaz wrote:
>> I have compiled this version to try the new "ANGLE FOLLOW" feature in
>> LABEL. Using shp2img it works and it is a very nice feature. The problem
>> is that when I tried to use it with php-mapscript I received the
>> following error:
>> *Warning*: [MapServer Error]: getSymbol(): Parsing error near (FOLLOW)
>> I believe that it might have been something forgotten.
> What does your script do? Does it just load the map and then call
> $map->draw()?
> The code to parse a mapfile is the same whether it's called from the
> mapserv CGI or from PHP MapScript, so in theory if it works for one it
> should work for the other. Perhaps make sure your php_mapscript.so (or
> .dll) is up to date, you can call ms_getVersion() after loading
> php_mapscript to check that. Also if your build uses dynamic linking
> then make sure you do not have two copies of libmapserver.so (or .dll)
> lying around.
> Daniel
I might have explained myself in a wrong way. All the code worked
before, using mapserver-3.8.3, and if I comment out the "ANGLE FOLLOW"
it works in this version. I am using ka-map
(http://ka-map.maptools.org/) as a front-end of mapserver.
So I believe it is not a problem of installation or php code.
David
Desc: OpenPGP digital signature
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061004/5ebe3bfc/signature.bin
